I have an fw 350 model stove and i wanna know if this model allows me to go from 6" pipe off the stove and go to 8"outside
    Genius:
  • 1,015 Answers
I would answer this with probably. Are you going to be far enough away from heater before you increase pipe size to make sure furnace is venting flue gases properly? Next is there any other equipement that vents into this same vent pipe such as water heater? I'm not trying to avoid your question,just want to be sure you can do so safely. Thanks.
Posted on Nov 12, 2010
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
How do I measure stove pipe?
The accepted technique for measuring stove pipe is by the inside diameter. Simply because the outside diameter of double and triple wall pipe are much larger by comparison to the inside diameter. There's no standard for outside measurement that would transfer in a logical manner.
Oct 14, 2014 | DuraVent DVL Dura-Vent DVL 8-Inch Vermont...
Need stove pipe for snow flame corn stove a flexable 90 degree piece coming out from stove and two foot straight piece to go out the exterior wall plus cap piece for outside
You need to communicate with a supplier of this unit to get proper parts and also find out what type/specification of pipe is required in your local area.
Oct 05, 2014 | Dryers
Poor draft on savannah woodstove
Drolets are a real pain at times. Don't buy their pellet stove. Check your stove pipe to insure its clean and not blocked. This includes spark arrestor. Is you stove cap 2' higher than anything 10' away from pipe? Refer to install manual. If you are not getting an y back draft issues with smoke inside house you may need to add on a section of trip wall pipe at the top.
Feb 27, 2014 | Drolet Savannah 55,000 BTU Wood Stove,...
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
I boughta vermont castings model # 2610 cast iron radiance franklin stove it came w/pipes .............is it a direct vent or a b vent..reason why i am asking is he gave me a "t" pipe w/ screen...
It the opening on the stove is on top of the stove, it's a 'B' vent. If the opening is in the back of the stove it's a "Direct Vent". However, some models have a connection on the back that's facing up,. A 90 degree elbow can be used to convert it to a horizontal run to enter an existing chimney, but then it must elbow up to connect to the pipe that is required to line the chimney. You should not just stop the pipe above the damper. It needs to run all the way to the top of the chimney, then have flashing seal the chimney's clay liner and a termination cap on the top.
here is a link to the Owners Manual/Installation Instructions for a Model 2600. It installs the same way as the 2610. http://homeappliance.manualsonline.com/mdownloads/62b85343-a800-4898-85a1-3d6d3c524259.pdf
Hope this helps you sort things out and do a proper installation.
Apr 18, 2011 | Heating & Cooling
What year/model transmissions will fit a 1989 GMC sierra, 2500, 350 engine, 2-wheel drive? Thanks
A.T., VIN model "C" (4x2), TH400, 6 cyl
A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-305 (5.0L)
}A}}400}466495" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-350 (5.7L)
}A}}400}466496" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-379 (6.2L, diesel)
E>}B}}400}466497" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH700, diesel
A.T., VIN model "K" (4x4), TH400, 6 cyl
B@}}}400}466499" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH400, 8 cyl, diesel
A.T., VIN model "K" (4x4), TH400, 8 cyl, gasoline
A.T., VIN model "K" (4x4), TH700, diesel
FFC}B}}400}466502" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "C"
FFC}A}}400}466503" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "R"
ECB}B}}400}466504" type="radio" name="userInterchange" />M.T., 4 spd, 4x4, (VIN model "K")
M.T., 5 spd, 4x2
M.T., 5 spd, 4x4
A.T., VIN model "C" (4x2), TH700, gasoline
F=A}B}}400}466508" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH700, gasoline
}B}}400}466509" type="radio" name="userInterchange" />A.T., VIN model "R" (4x2)
Jan 14, 2011 | 1989 GMC Sierra
Please show me the position of the #1 spark plug wire on the 95 350's distributor
If you are talking about a 350 Chevrolet (GM) engine, the #1 plug is at the drivers side front. To find the position on the cap, turn the engine 'till the timing mark on the lower pulley points to 0 on the scale, then check rotor position in the distributor. If it's pointing towards the firewall, make one more turn. The firing order goes in the direction the rotor turns when cranking the engine over. 18436572.
Jun 28, 2010 | Cars & Trucks
I need a diagram for firing pattern for a chevy 350 motor
For the 1987 Chevrolet Blazer 350 (5.7L):
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back)........
|..8..............7..|
|..6..............5..|
|..4..............3..|
|..2..............1..|
........(front)
Distributor Connections:
.....(back)
.....6.....5
3...............7
4...............2
.....8.....1
.....(front)
Rotation:
Clockwise
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Jun 19, 2010 | 1987 Chevrolet Blazer
I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system...
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
Apr 01, 2017 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
