Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
If I on the power, display at LCD said 'Reinsert the cassatte' and C:31:23. Why?
    Guru:
  • Sony Master
  • 2,178 Answers
The timing cam is misaligned. Its' purpose is to eject the carriage, transport the tape into the heads when there is a tape and play or record the tape. If the gear is off slightly then you will get the error. It needs to be taken apart and re-aligned.
Posted on Nov 12, 2010
Meron power pero ayaw mag on
Hi arcymiguel,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 16, 2011 | ASUS Laptop with Intel Centrino Processor...
Hp g60, power light comes on, wireless light is orange, charger works ok but wont power up
Hi kr 2583,
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
Hope this helps.
Jun 11, 2011 | HP G60-230US Notebook
I have presario CQ60 211ed power on but no display and not laoding
Hi cris rubis87,
Hope this helps.
Jun 09, 2011 | Compaq Presario CQ60-220US PC Laptop
Toshiba m100 my hand trying to have a power LED and battery LED fan works but I can not display the image signal.
Hope this helps.
Jun 03, 2011 | Toshiba Satellite M100 Notebook
When I try to print it displays on the small screen bypass letter add paper. How to solve thanks
see what size your printable area select the correct paper size, in page set up select paper size to A4, and your copier Cassatt to A4 size
Mar 17, 2011 | Panasonic DP-8020E Black and White Copier
Harmony 890 lcd stays on without displaying the
Hey!
I had this same issue with my Harmony Remote. Logitech sent be these steps and they got it working right!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.7).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
I hope this gets the display on your Harmony Remote working too!!!
-Kennedy
Sep 27, 2009 | Logitech Harmony 880 LCD Remote Control
Error code C:31:23 model DCR-TRV285E
Hi!
I have experienced the same problem with another TRV model. Crude as it may sound, whacking my camera a few times made it work for another few months before I finally had to have it serviced.
Don't worry, though. From my experience, the repair (something with the tape mechanism broke down) costed me only about $20 in parts.
Hope this helps!
Nov 08, 2008 | Video Cameras
No LCD display
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Pentax Optio S4 Digital Camera
My dcr trv 285e camcorder is not going in play mode.
Try to open cassatte cover fully ,and cassatte is automatic comes out.
Dec 06, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
118 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
