Question about Lexmark C912 Led Printer
"981 Service Switch Error"
  • 270 Answers
981 service switch error refers to BUD(belt up/down) clutch if the error essage is hard. it could be possible that someone could have playes with white CAM below the tranfer belt(behind the waste toner box) if you suspect that the cam was manually rotated, then you are in a big FIX. if not then it could be just a problem with the cam being worn out. in this scenario you cannot remove or reset the transfer belt as you normally do it. there is a special procedure to remove the transfer belt. try the following.
remove the waste toner box., fool the front door of the printer so that you can watch the transfer belt moving up/down. while you have the fron door open,
Turn off the printer, press and hold the go and return buttons on the printer , keep watching the shaft that show the position of the belt, once it moves, be fast enough to turn off the printer. If you were successful in this procedure , you can remove the belt from the printer without any problem. Make sure not to touch the white cam shaft. visually examine the internal mechanism of the shaft, if it is wornout replace it.
IF the white cam was turned manually then you might have to replace the BUD clutch.. which is the most difficult process in this machine....Wish you all the best.
Posted on Nov 12, 2010
Why wont power come back on the unit all the fuses are good
Never use a staple on a power wire.
Remove the staple and check for damage within the sound bar.
Feb 27, 2017 | Denon Audio Players & Recorders
Do u have a ticket on my car,toyota corrola 1.3 professional model 2009.hvy 981 nw?
fixya doesnt write out traffic or service tickets ---resubmit your request to the correct location
Sep 19, 2016 | Toyota Corolla Cars & Trucks
How can I correct error code sc 981?
SC-981:Hard drive response error
check cables and format hdd. reset error. if error recurs then replace hard drive
Feb 06, 2016 | Ricoh Aficio Office Equipment & Supplies
Printer error support code 5B00
Call to expert for help +1(404)981-1535
Jan 13, 2016 | Canon PIXMA MG6320 White 6226B024
SC 28113 Error
Hi this is Alex Walker i will be glad to assist you Call me +1(404)981-1535
Nov 18, 2015 | Office Equipment & Supplies
When i select my programmed check voicemail button i get an error of "not in service". how do i fix this and re-establish it as the check voicemail shortcut?
Try Feature *3 - press the button you had programmed of check voice mail - the press Feature 981. This should reprogram your button.
Aug 20, 2013 | NorStar T7316E Corded Phone
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Phillips secuity code
If you ring Hyundai Information Service on 0800 981 981. They will be able to give the code for your radio
Mar 14, 2008 | Audio Players & Recorders
"981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Feb 17, 2008 | Lexmark C912 Led Printer
Lexmark C912 Led Printer Logo
402 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
