Question about Hotpoint Ultima WF865 Front Load Washer
I want to know how to fit a new belt to a hotpoint washer/dryer wd865
  • Hotpoint Master
  • 3,463 Answers
Remove the rear panel of washer, and tilt washer forward away from you with someone to hold it steady.
Fit the belt round the motor pulley first and slowly feed it round the drum pulley turning the drum pulley at the same time,
It will be very tight, so watch your fingers.
It may seem to be too small, but persist with it, and it will go on.
Posted on Nov 12, 2010
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Wd865 error f01
f01 is a motor problem. may need a new one but an engineer visit would confirm this.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer dryer wont stop running
unplug the machine for 3 mins and plaug back in if it still happens you might have a problem with the heating element or somthing.hope this helps.
Jan 02, 2009 | Hotpoint Aquarius WD63 Front Load...
How to fit a new belt to a hotpoint condenser dryer TDC 32
My advice to u would be to call an engineer to fix it, as it it involves a complete strip down, and is not an easy job to undertake unless u are prepared to spend a lot of time and effort, I speak from personal experience, so I know what I am talking about.
But again if u think u can do it then good luck, but don't say I didn't warn you!!!!.
Plz rate my suggestion.
Thanks
Dec 30, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wd420
your drive belt runs from the elec motorpully and then round the drum ?? so if yo look at the motor you will see it resembles rather like car alternator ?? and is fitted with a method of adjustment much the same ie a slide adjust bracket ? which you will slacken bolt/nut to enable motor to slide to a point enabling the fitting of belt? then with a suitable imlement? swing(lever )the motor till belt is taught and re tighten adjust bolt/nut also check the pivot mounting bolt/s/nuts are tight hope this helps
Oct 24, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
My Hotpoint washer dryer WD865 moves around the room making loud noises when on a fast spin? The internal drum seems more loose than normal?
I had the same problem. You can open the top lid (2 screws at the back and then lift) The weight which is on top is secured by three bolts, all three of them were loose so weight was going from one side to another which made a terrible noise. Tightened the bolts and noise was gone!
Dryer still not working though.....
Aug 06, 2008 | Washing Machines
Hotpoint Ultima WF865 Front Load Washer Logo
301 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
