Question about Belkin (F5D7230-4) Router (587009)
I forgeten ip address of belikin model no is f5d7234-4-h v5. how to know
  • 1,679 Answers
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Hope this is helpful.
* Dont forget to rate this solution and write comment
Posted on Nov 12, 2010
I need to know how to complete my setup I got as far as the setting screen where they ask u your IP address etc. Now I can't get in to complete the set up. What do put in those blanks that ask for you
If you are in the Router setup, (and not a PC setup,) then that would only apply if you had a "Static" Public IP address, (this is an address that never changes, vs. 'Dynamic' ones that do change.) Usually only a business would have 'static' Public IP addresses, and the Internet Service Providers (ISPs) charge extra for them.
Without knowing more about the make/model Router you have, it would be difficult to give you further instructions, but look for settings that would assign the IP address 'automtically'
Oct 12, 2014 | Computers & Internet
How to config my belkin n300 to change nat to open in xbox live
Belikin has one DMZ IP option in the web admin.
Go to Portforward dot com for step by step instructions. Also refered to as virtual servers on some routers.
Dec 29, 2012 | Belkin Surf N300 Wireless N Router
Hii there I have bought a Belkin wireless Router G F5D7234-4-H V5. Im from Bangladesh and using windows 7 professional as OS. Several times I have tried to setup using the web browser format which was...
Make sure the you are wired correctly. 1) The incoming cable/dsl to the modem. 2) The modem to the WAN (Internet) RJ 45 connection on the router. 3) The router wired to the computer during set up. You can not set up the router unless you are hard wired to the router.
Then try connecting using the IP address Belkin sent you. Probably 192.168.1.1 or 192.168.0.1. Use Internet Explorer.
May 16, 2011 | Belkin (F5D8231-4) Wireless Router...
I have a Netgear DG834GU v5 modem and have forgotton the password for Wi Fi, I wish to use it on my ipod. Could you help me find a solution? Regards Nat
Press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
Use this method for cases when the administration password or IP address is not known. These steps restores the router setting to factory defaults. (e.i. administration password to admin and the IP address to 10.0.0.2.
eds6524
Jan 11, 2011 | NetGear DG834G Router
I need to open my nat for xbox live router f5d7234-4 v5
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Oct 11, 2010 | Belkin F5D7234-4 Router
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
I AM USING A BELKIN G WIRELESS ROUTER MODEL F5D72...
Either you have not configure the Wireless SSID or your router is faulty. You can use the easy setup using the CD or configure the router by going to the default IP address. Do read the setup manual first.
May 20, 2010 | Belkin (F5D7230-4) Router (587009)
Need my password or key for wii consule
You can find it out by looking at the router setup page:-
http://kbserver.netgear.com/products/WGR614.asp
Select your router model (v5,v4..) and look at the docs on the webpage.
You can login to your router by using one of these IP addresses http://192.168.0.1 or http://192.168.1.1 in your browser address bar.
You will see your network key under the wireless settings.
Hope this helps.
Jan 22, 2009 | NetGear WGR614 Wireless Router
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
178 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
