Question about Crosman Optics
I BOUGHT A CROSMAN PHANTOM AND CANNOT FIND AT ANY OF OUR LOCAL SHOP - NOR FROM CROSMAN - THEIR RECOMMENDED RMC OIL TO LUBRICATE THE CHAMBER SEALS. WHERE CAN I BUY CROSMAN RECOMMENDED RMC OIL?
2 Suggested Answers
Goofguyster
  • 379 Answers
SOURCE: oil in spark plug chamber
there called spark plug tube seals and they are leaking they are easy to replace
Posted on Apr 04, 2013
Will not hold air
You need a set of gaskets. Google
make model calibre gaskets
or take it to a sports shop, gun shop that does air rifle repairs.
Nov 25, 2017 | Crosman Phantom .177 Caliber Break Barrel...
The BBs won't come out or shoot.its a crosman MCSR01 air gun
Seal leak in the air chamber.Need new seals
Mar 15, 2013 | Optics
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
When I **** the barrel to compress air it won't stay cocked, so I can't shoot. The gun is new and I tried to take it back to the store and they said they only sell them. I have a crodman phantom CS1K77SM...
If it new, it must have a warranty of some kind. Use the link below to contact customer service for help.
Crosman recommends that you take to a service center, and adds the following. >DO NOT ATTEMPT TO DISASSEMBLE IT< Your Phantom requires special tools and fixtures to repair it. Any disassembly or modification not performed by an authorized service center will void the warranty.
Crosman customer service
http://www.crosman.com/airguns/service
Dec 06, 2010 | Crosman Optics
My model 822 wont pump and it sounds like th air is comeing out of the reciever when you do try to pump it
Hi, You may have to replace the seals or O'rings.maybe both. Who makes the 800? Daisy or crosman?I have a list of companys that service airguns.Please write me back and tell me.Hope I can help you out.Joseph A Bagli.
Feb 15, 2010 | Crosman Optics
Will not chamber a pellet for Crossman 357 .177 cal pellet gun
http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
Read this and make a decision based on the information contained within.
Feb 06, 2010 | Crosman Phantom .177 Caliber Break Barrel...
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
It takes 12 pumps to get a strong shot off and side spring load d
Hi Guy
There are 3 types of air rifles. Pump, Spring, and CO2. You have a Pump. These work by compressing air into a cylinder at the base of your rifle (where the chamber should be) and releasing it when you hit the trigger out the back of the cylinder. In that is a few Rubber O Ring seals that deteriorate under higher pressure than they are built for (10+ pumps). For the performance to be improved you would need a new O ring from the manufaturer (only if your gun is expensive enough (300+??)(there are some air rifles that are break action with like 40 pounds of break and are spring. subsequently they fire at over 1000 fps up to 1300 or 1700 or something i cant remember, but the require a firearms license or to be bought and delivered to the local police shop and picked up) so if you rifle is expensive enough you can get a new part. If not you can get a new rifle unfortnately and keep that one as a beater. To maintain that gun donnot charge it past 11 Pumps this should prevent further deterioration.
As per the sring is a pain in the as to load your gun, that comes down to how expensive your gun is again. if you get a cheap one they usually have you hold open the chamber. Better models have a reccess inwhich you can rotate a plastic nub from the spring into to lock it down. Other models use clips etc.
My suggestion if you do decide to go get a new one. Buy a break action. You cant overpower them and they are extremely quick to reload. (the constant pressure of a break (same pressure each fire) can help you fire better too).
You could also take the gun apart A LITTLE BIT it is a few simple pieces. GL
Apr 03, 2009 | Crosman Optics
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
Mar 29, 2009 | Crosman Phantom .177 Caliber Break Barrel...
This is a new pellet rifle, but it is not getting sufficient compression. DH would like to know what to do to fix it. Thank you, daht
Lubricate everything generously with Marvel Mystery oil.Your new pellet gun is probably leaking around the seals.Oil improves the seals.Be sure to wipe off excell oil before shooting.
Mar 10, 2009 | Crosman Optics
Optics Logo
50 people viewed this question
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
