Question about Canon PIXMA MX310 All-In-One Printer
Printer problem i have an Canon MX310 Printer that says first that it has a paper jam and then second starts to create a loud noise and gives me an error Check ink U053
  • jovan1984 Aug 17, 2008
    Printer makes a loud noise and has an error that reads "check ink" U053
  • Anonymous Feb 01, 2009
    i have a canon pixma mx310 andd everytime i press print it says check ink u053 and i have just put in new ink
My Canon MX310 doesn't like recycled ink cartridges, but doesn't do this.
Rjams
Posted on Jun 24, 2008
Why does my Canon printer MX310 show paper jam when there is no paper jammed?
Hi
try switching printer off & on. If that doesn't work, check the paper path for stray bits of paper or another obstruction.
Sep 20, 2014 | Canon PIXMA MX310 All-In-One Printer
The paper had jammed when i was printing, i removed the jammed paper and tried printing again. however, the display on the printer shows paper jammed. what now?
You may have left behind a tiny piece of paper that tore off your sheet as you removed it. Make sure that you have all of the jammed paper and look carefully for any remnants inside. Look to see if the printer did not pick up a second sheet that is still in the system somewhere.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 indicates paper jam but no paper
The printer has several switches in it to detect paper jams. When paper feeds in it trips the first one indicating that paper is present. Another switch further along the feed path indicates that the paper is feeding okay.
Your problem can be a jammed switch (loose scrap of paper), a broken switch, a switch disconnected from the controller board or a possible bad controller board.
One thing you didn't mention was does it respond the same with paper loaded? It might be that the first switch is looking for some and not finding it, so it is programmed to assume a jam.
Aug 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper jam
Its a mechanical fault in printer. Give it to service center for servicing.
Thanks.
Happy to help you..
Apr 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Jun 21, 2009 | Canon PIXMA MX310 All-In-One Printer
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
538 people viewed this question
old marine
old marine
