Question about Wega Mininova EPU Espresso Machine
Brand new EPU/1 Mininova (just delivered to me in Perth from Melbourne today 12/11/2010). The pressure gauge remains stuck at zero. Earlier, I had managed to get the machine working by using the Hot water dispensing push button and running two big cups of water through the machine. This raised the pressure to about 1.1. I made 1 espresso, that was OK. Then, half-way through making a double espresso, the machine stopped, pressure went back to zero. Manual says to contact technical service if this happens. Please can you assist. Andrew
  • Andrew Hunwick Nov 15, 2010
    I have had to return the machine to the suppliers, in order not to void the warranty. But it seems nonetheless that your solution is quite correct (an airlock somewhere in the machine). Thanks for your expert advice,.Andrew
  • 2,299 Answers
It sounds like the water line is blocked. There is an obstruction in the line somewhere. This must have happened at the factory. You could disassemble the machine, but would void the warranty. And I believe that you will need the warranty in the future for other problems. I know that it is not the news that you wanted to hear. But if you want to disassemble the machine let me know and I will try to explain.
Posted on Nov 12, 2010
Find an address
White Pages® - Search for an Australian Business, Government ...
https://www.whitepages.com.au/
Browse location: ACT, NSW, NT, QLD, SA, TAS, VIC, WA, Sydney, Melbourne, Brisbane, Perth, Adelaide, Canberra, Gold Coast, Newcastle, Townsville Business ...‎New South Wales · ‎Victoria · ‎Queensland · ‎South Australia
White Pages, Call Us - White Pages®
https://www.whitepages.com.au/white-pages-10060395/call-us-10060394B
Jan 25, 2017 - Connect with White Pages. Look up phone numbers, opening hours, directions & more using White Pages®
M Residential in South Perth, WA - White Pages®
https://www.whitepages.com.au/m-residential-10474769/south-perth-wa-10474768B
Connect with M Residential in South Perth, WA. Look up phone numbers, opening hours, directions & more using White Pages® perth wa Google Search
Feb 14, 2017 | Cars & Trucks
Can you deliver witlof to Perth?
SORRY this is not a food ordering website .we do not have anything here for sale nor do we deliver any produce any place
May 30, 2016 | Cars & Trucks
Im looking to source a wega Mininova espresso machine in SA?
Wega is good, generally, but avoid this Mininova. Tell me if you are looking to a home machine, or for commercial use. Either way, it proved unsuitable. We gave many Mininovas to scrap dealers, having made the mistake of damaging our reputation by promoting them.
Nov 12, 2013 | Wega Mininova EPU Espresso Machine
Wega espresso
Steam out of the top is a bad safety valve.
Steam out of wands when they're off is bad gaskets in the valves which usually means they need to be rebuilt.
Steam out of groups is a water blockage and/or pressure stat is going bad and causing the machine to over heat.
Can be any one of the following. Need more information to answer properly.
May 02, 2013 | Wega Mininova EPU Espresso Machine
Wega Espresso Machine is slow to recover steam pressure
Bad pressurestat or bad heating element. PS feeds power to heating element, heating the machine til its up to pressure, which then turns the pressure stat off. If either of the two pieces are bad neither will work properly.
Could also be the machine is overfilled which causes the machine to take longer to heat up.
Sep 20, 2011 | Wega Mininova EPU Espresso Machine
Miniwx epu no water coming from group head to cup no water at cylinoid
Since there is no water at the solenoid, then the blockage must be at the metering jet, which sits under the nut on top of the group, turn of water supply and be careful when removing nut do not damaged o-ring if it is not a teflon O-ring, you might have a leak. Clean out jet and filter then reassemble.
Apr 17, 2010 | Wega Mininova EPU Espresso Machine
Leaks when filling with water
Check with espressopartsnw, they have a large selection of parts, if you cannot find it under wega look under astoria or rio same machine.
Sep 08, 2009 | Wega Mininova EPU Espresso Machine
Pump problem
Do you have a manometer on the machine and if yes, what is the reading when you are pulling a shot, does the gauge move, have you opened the side of the machine to see if the pump is turning, you might have to adjust the pressure on the pump by using the adjusting nut instead of replacing the whole thing.
Jan 10, 2009 | Wega Mininova EPU Espresso Machine
I have an Acer 5315. It turns on and boots up, with the battery light and the power indicator light are both on, however the screen remains blank. I believe that the resolution of the screen has been...
You may using recovery disk and perform re installation of graphic drivers. However if you have Acer warranty please seek their advice first.
Brisbane - Australia
Here is contact info
Acer Computer Australia Pty Ltd.
Leigchhardt Court, Ground Floor
55 Little Edward Street
Spring Hill QLD 4000
Tel: +61-7-3226-3888
Fax: +61-7-3226-3899
Melbourne - Australia
Unit 4, Ground Floor, 601 St Kilda Road
Melbourne, VIC 3004
Tel: +61-3-9522-0928
Fax: +61-3-9522-2800
Perth - Australia
Level 3, 30 Hasler Road
Herdsman Business Park
Perth, Osborne Park 6017
Tel: +61-8-9244-5888
Fax: +61-8-9244-3762
Sydney - Australia
#5 Figtree Drive, Australia Centre Homebush Bay, NSW 2140, Australia
Tel: +61-2-8762-3000
Fax: +61-2-9764-2368
http://www.acer.com.au/
Oct 10, 2008 | Computers & Internet
Wega Mininova EPU Espresso Machine Logo
145 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
