Question about Dishwashers
Hi Masters! My dishwasher was stopped during the program and the second LED ( from the four ) is flashing. Please send me the ARISTON LS 248 T dishwasher error code list if you could or please give advice for me. Many thanks,
  • 3 Answers
SOURCE: Hotpoint FDW60 dishwasher - flashing lights
check the filter.
Posted on Jun 06, 2008
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
SOURCE: Error code E:24
bosch logixx error code: e24?
Posted on Sep 20, 2009
SOURCE: Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Posted on Apr 26, 2010
SOURCE: need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Posted on Oct 14, 2010
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
Why Ariston lbf51 washing and drying light rapid flash
AL03 - Drain Timeout (drain problems)
LED 1 (washing) and LED 2 (drying) flashing.
Probably the siphon of the apartment is clogged.
  • Remove the drain hose and make sure that is not clogged.
  • Drain water in a bucket.
  • If the dishwasher drains the water, clean the siphon of the apartment.
Dado
May 25, 2014 | Ariston Technologies LL65 Built-in...
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
May 25, 2014 | Ariston Technologies Dishwashers
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Need to find parts dealer for Ariston dishwasher
Feb 02, 2009 | Ariston Technologies Dishwashers
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
