Question about HP Photosmart C6380 All-In-One InkJet Printer
My printer model is Hp C5383 all-in-one & the printer is flashing the message "ink system failure Oxc19a0023" on the screen. What can I do? Pls help me.
  • 270 Answers
You may try this step to to fix this problem
Solution 1
  • Turn the unit off,.
  • Unplug the power cord and wait 30 seconds before reconnecting the power.
  • Turn on the printer
Solution 2:
  • Press and hold "left arrow" key
  • Press the "setup" key and release both keys
  • Press and release the "OK" button
  • Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
  • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • Press and release the "OK" button.
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Do not print at this stage.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • If the error is still there, or reoccurs the printer is already defective.
Solution 3:
  • Press the On button to turn the printer off.
  • Unplug the power cord from the back of the printer.
  • Remove all the ink cartridges.
  • Wait two minutes.
  • Plug the power cord into the back of the printer.
  • Press the On button to turn the printer on.
  • Install the ink cartridges when prompted.
Solution 4:
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges ' message to display on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button (My printer model is Hp - c01602202.gif ).
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Nov 12, 2010
Oxc19a0023 ink system failure. Called HP Tech, and he advised me to enter the Red Eye Removal, Print Photos both together, it didn't work. Then I found the same directions on Fixya.com, so have done...
Try this solution.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-2/
The "ink system failure" is caused by air in the ink nozzles. The clear the error you need to do a full purge of the system and the above procedure with do it.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 28, 2011 | HP Photosmart C6280 Printer
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink systerm failure for hp Photosmart C6380 Oxc19a0023 Printer ask me to restart,but after I did several times, it still showing Oxc19a0023 code on the screen.
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Oxc19a0023 INK System failure
TRY THIS
Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
Display should say "Support". Use the Right arrow Key to look for "Reset Menu".
Press the right arrow key to look for "Partial Reset", press 'OK'
The printer will go off and will power on by itself, else wait for 20 seconds and power on the printer to complete reset
reset process for c6380
Apr 09, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP Photosmart C6380 All-In-One InkJet Printer Logo
314 people viewed this question
Seeker5211
Seeker5211
