Question about LG 42PG60 42 in. HD-Ready Plasma TV
CAN'T TURN TV ON. SWITCH FLASHES ON/OFF SEVERAL TIMES THEN STAYS IN THE ON POSITION BUT WITH NO CONNECTION.
  • 335 Answers
Ok,
Whats happening hear is that the power supply has a fault or is detecting a fault from another board and shutting its self down. There's an over-voltage problem somewhere on the circuit boards, its an LG tv so its easy to service and shouldn't cost much because its plasma.....
http://tvtechwork.webs.com/
Posted on Nov 12, 2010
Testimonial: "Many thanks will contact service engineer for repair with an idea of what is going wrong. Cheers."
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
I have a 52A650 and the TV shut off and turns on several times before it stays on the the night.
The tv now flashes it power light indication's alot?Turn off/no at least 4 or 5 to turn on tv now?Tv power supply board,that the board,where the power a/c cord plug into it.That the power supply board have problems and dying,must be replaced.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 28, 2010 | Samsung Touch of Color LN52A650 52 in. LCD...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 14, 2009 | Directv RC23 Remote Control
You just dropped me without answering my question or really even trying
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | One For All URC-3021 Remote Control
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Frozen up
try a reset. toggle hold switch on and off then press menu button and center button at the same time. hold both buttons down until the screen flashes. You may have to try this several times.
Jul 30, 2007 | Apple iPod MP3 Player
LG 42PG60 42 in. HD-Ready Plasma TV Logo
305 people viewed this question
Computer Repairing
Computer Repairing
