My tv did not come back on after a power cut could it be the fuse
  • 927 Answers
Good Day;
After a power outage it is best to 'reboot' the TV. Unplug the TV for 4-5 minutes from a/c outlet, wait, plug back in. Did not work?
It could be the main fuse, it will be located near the a/c cord on the TV's board. CATION!! After removing back of unit make sure the TV is unplugged from the a/c outlet and the fuse will be a glass fuse, ensure that it the correct value eg; 5 amp 250v.
Good Luck and Careful, Big Irish.
Posted on Jun 18, 2008
Hi my tv will not switch on after power cut it's a wharfedale l22t11w-a can anyone help
Check for power at the wall outlet, check for a manual switch/circuit breaker/fuse on the back. Check the battery in the remote, is it good.
The internal switchmode power supply usually has a power disconnect fuse, it may have operated. Internal components are difficult to service unless your a trained tech with the correct tools to disassemble the TV. Suggest you take the TV to a repair shop.
Apr 07, 2014 | Televison & Video
TV has no power after power cut
Fuse inside tv or power supply most likely fuse
Apr 04, 2014 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power....
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Aug 25, 2013 | LG M4201C-BA 42 in. HD-Ready LCD
Sanyo tv cuts on then right back off
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_17_54_pm.jpgbad caps that are puffed up on top..
Apr 10, 2012 | Sanyo Televison & Video
Due to high voltage spark occur in my tv and then there is no power light in the tv model bpl djr-21
Hi
Open the TV at the back with a screw driver, then go and check the the fuse if it has not cut. the fuse is like bulb with thin wire. If it has cut, you will have to replace it it is very cheap to buy. check the # on it to know the right fuse that you will buy when you get to the store.
If there is nothing wrong in the fuse, then, the transformer is faulty.
Use a multimeter to check if the transformer is reading, if not replace it.
Thanks.
Jun 20, 2010 | Televison & Video
Tv not powering on
have your tv checked by a tech your problem is in the power supply or related circuit.check your regulator,along with some caps the microchip.good luck
Jun 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where do i find a fuse on my JVC AV 3150S tv .. My Tv cut off and wont turn back on. when I push the power button, I get a high frequency pitch but thats it... I was told it was most likely a fuse.. what...
Please believe me when i tell you it is NOT the fuse at all. It is the switchmode power supply shutting down for safety reasons, you need to get the set serviced.
Mar 19, 2010 | Televison & Video
We had a power cut and then turned T.V back on and it made a
check all the fuses u will find the prob, every board has at least one fuse.
Dec 07, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My TV won't come back on.
the fuse on the main board is blown.replace that fuse.
Nov 14, 2008 | Televison & Video
I have a goodman LD3755HD TV tonight we had a power cut while the tv was on . now the power is back I cannot get the tv to turn on. Tried fuse, batteries in remote, all the usual. is there a reset button...
It could have blown the internal glass fuse/s on the power supply otherwise its a component on the power supply board. Failing that it would have to be in fornt of me lol. Good luck.
Sep 29, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
