Question about Dometic Rooftop RV Air Conditioner
Dometic roof A/C fan
The fan will not start up with the A/C, not even if I select the fan only position from the selector switch. I can hear the compressor kicking in in the cooling mode. The fan is free to the touch. If i spin the fan slightly and select the switch the fan runs in cooling or in the fan mode in all three speeds. My finding is that the fan does not or canno start on its own. What controls the stating function of the motor.
  • olmac Jun 19, 2008
    Hi Thank you fort he help, but as I mentioned before the fan will run as usual on all three speeds if I give it a spin to start it up. But the fan will not start up from a dead stop. Once the unit stops after raching the thermostat setting the fan deeds another push. I have two capacitors, larger one and another small one with a starter on top of it which shows some signs of brown colour. So can Iassume the motor is still in good shape and the capacitor is diffinitly the problem here.
    Scholar:
  • 104 Answers
If the fan motor is humming when you turn on the fan switch and it seems like if you spin the fan, it wants to try to spin on it's own but can't-your problem is the run capacitor. This will be a small round or oval cylinder that connects to the motor with either two or three wires. On the side of the capacitor should be a label or printing the size of the capacitor is rated in microfarads which is indicated either uF (the u will have a little tale pointing down on the left side) or MFD. Match this up to a new capacitor of the same size. Voltage rating of the capacitor is not important as long as it is 370 volts or higher. When you hook up the new capacitor, which terminal the wires hook up to is not important HOWEVER, if there are two wires going to one of the terminals, those two wires must stay together and go to one of the terminals together on the new capacitor. If you follow all of these instructions and the motor still does not work, then the motor has failed internally somehow and will have to be replaced. Whenever you replace a motor, ALWAYS replace the run capacitor that goes with it.
Posted on Jun 18, 2008
Hello, I have a duo therm ac unit, the fan works fine in all the Fan only speeds, but when the ac is selected, the compressor comes on and the fan drops down to less than half speed. you can hear the fan...
Check incoming voltage circuit and wiring for proper gauge wire etc, and have compressor start capacitor tested, or replaced. I'm curious as to why circuit breaker didn't trip in panel when compressor causing so much current draw, that's reason for checking wiring etc to AC circuit.
Sep 14, 2011 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
142 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
