Question about McCulloch 14" Electric Chain Saw Mcc1514
My saw runs great for about 5 minutes then it seems to over heat and it quits running.
    Genius:
  • 1,015 Answers
There are several things that can cause this problem First if you run it until it quits will it start working again after it cools down. If this is the case the it is shutting off thermal switch on motor. This could be from saw needing cleaned or lubed, make sure chain is not to tight, don't force saw to hard,let it cut at its own pace. Make sure chain is sharp. Anything that causes excessive friction will increase motor temperature. It is possible that thermal switch is about worn out. Hope this helps. Thanks
Posted on Nov 12, 2010
Testimonial: "I think that is my problem.Thanks"
My new poulan will start and run great for about 5-10 minutes then will just quit running. let it set and cool down and it will do the same thing why?
important to use correct oil and mix. no guessing. too much oil mix fouls up the engine. make sure blade is adjusted properly and not gummed up with oily debri
Feb 14, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What would cause a poulan chain saw to quit running after about ten minutes of cutting
The only temperature sensitive part I can think of is the condenser. In most saws it is under the flywheel with the points. Some newer saws have an electronic ignition module. If that is the case the module must be replaced.
Oct 15, 2014 | Poulan Garden
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
My saw starts fine, runs great for about 5-10 minutes, then dies. If I let it sit for another 5-10 minutes it fires first pull and runs strong- for about 5-10 min then dies. Any ideas? Thanks.
Hello. Check the filter in the bottom of the fuel tank, I am betting that it is partially gummed up and restricting the flow of fuel. Regards, Joe
Jan 05, 2010 | Poulan Garden
Stihl saw 026 runs 5-10 min won't stay running and backfires
5 to 10 minutes is a long time and the 026 is a fairly old saw. If it is running 5 to 10 minutes and not 5 to 10 seconds, you probably just have a worn engine. Clean the saw inside very thououghlr and try Amoco white gas. You should be able to reduct the heating and get more run time. A carb rebuild might also help some but in hot weather it is not unusual for chain saws to vapor lock.
Sep 21, 2009 | Garden
Saw quits running after about 30 minutes
try a new plug then it could be down to faulty coil if no joy make sure all cylinder shrouds are in place as is could also be overheating causing a breakdown in ignition system
Mar 31, 2009 | Husqvarna Viking 1
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
McCulloch 14" Electric Chain Saw Mcc1514 Logo
263 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
