Question about Dishwashers
I need the stainless cover at the bottom of the outside of the dishwasher
  • Dishwashers Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Nov 12, 2010
Se code Samsung DW80F800UWS What should I look For?
Theres a 5E I can't find a Se
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Nov 22, 2014 | Samsung 24 " Built-In Top Control...
I have a loose handle on my lg ldf6810st dishwasher. Can I remove the inside of the door and tighten it?
I think these have set screws located at the bottom of the handle on the outside of the machine..
Best regards
Ck
Mar 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
It will not turn on, we've checked the circuit breaker and opened and closed it several times, still will not turn on.
Check to see if your getting power at the main board. To get to the main board, open the door and remove all of the screws around the door. This wil allow you to take off the outside cover. The power wires are the black and white wires on their own terminal going into the board. Careful because they should be live. If you are getting power here, you will need to replace the main board, if not check the connections to your dishwasher where line voltage comes in, located on the bottom right corner under the kickplate. Hope this helps.
Jan 31, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
The bottom panel (on the outside of the dishwasher) will not stay in position - it keeps falling down. There does not appear to be any brackets or hooks to hold it in place. Thank you
if you are talking about the stainless steel panel they are usually glued on. there is some history of the glue letting loose on stainless appliances
Oct 24, 2010 | Asko D1776 Stainless Steel Built-in...
The inside of the dishwasher bottom is a film like covering. It is cleaning dishes great but the stainless steele bottom looks awful. Help!
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
F2 Error code beeping
your pump has seized.To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover.
Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. My blue impeller had come off and lifted off with the brown ring leaving the rest of the pump stuck in the hole! I eventually managed to get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go.
May 01, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The inside of the dishwasher bottom is a film like covering. it is cleaning dishes great, but the stainless steele bottom looks awful. HELP!
this is usually scale build up and can be remove by using lime away. and run the unit in an empty cycle. there are dishwasher cleaner that can be bought from local parts or home improvement store
Mar 28, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I don't have a problem, but would justy like to
Hello. Not all dishwashers have multiple panels which you can interchange. However, you always have two other options. One is to paint the white cover with stainless steel spray paint.
You can do this yourself with spray cans available from home depot, or you can remove the door and take it to an autobody shop to have it professionally done.
you can also have a piece of stainless sheet metal cut to size at a metal fabricating shop and use a construction adhesive to attach it to the front of your dishwasher, using stainless outside corner trim to finish the job.
Oct 25, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Need to replace stainless steel outer door something etched in stainless will not come out on kitchenaid dishwasher
I'm not sure if they have the solution for your model but applianceart.com has faux stainless covers and they sell stainless dishwasher door panels.
Oct 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
