Question about MicroBoards GX-1 50 Disc DVD/CD Publisher - Shipping Burner
Disc not feeding
My disc will not drop down and feed through the machine
  • cesi Aug 04, 2008
    yes i do also no print at all
Print problem
Posted on Aug 04, 2008
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
Feed dogs do not drop for darn Bernina 831
Old oil has dried and is causing parts to seize. Feed dogs are a frequent indicator of this condition. Stitch selectors also tend to be affected. Eventually, the needlebar will seize and the machine will totally stop.
Aug 07, 2017 | Bernina Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
Material won't feed just stays in one place, the drop feed control doesn't move the teeth.
hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Apr 19, 2009 | Singer Sewing Machines
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Drop feed
I found the drop dog feed lever. Problem solved.
Sep 28, 2008 | Sewing Machines
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Sep 20, 2008 | Sewing Machines
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
MicroBoards GX-1 50 Disc DVD/CD Publisher - Shipping Burner Logo
335 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
