Question about Philips 55PP9401 55" Rear Projection Television
Can you show me how to Replace convergence IC's? Ste by step? Sorry, I never done this before.
  • Philips Master
  • 3,459 Answers
Get a service manual from www.magnavoxhelp.com
Posted on Jun 29, 2008
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Mitsubishi ws-55711 I push the power button and the light goes on for a second and goes out. I did the diagnostic check and it shows 2 blinks then 2 blinks. Do you know if this is the fuses and if...
2,2 is the error code for short protection.
The most common reason for this is one of the 2 pico fuses that protect the convergence circuit is blown. Changing the fuses will not help! They are green in color and soldered into the middle circuit board and are F9a04 and F9a05----look like resistors but are 5 amp fuses.
99% chance if one or both are blown---you have to have someone change the STK-393-110 convergence IC that this set uses----the IC can be purchased on Ebay for under 14 dollars and the same seller sells the pico fuses 5 @ 2.95.
The best thing to do here if you or someone you know is able is to unplug the set and look for the fuses---middle board towards the back---there are 5 of them and the two closest to the back of the row are for the convergence IC----If someone checks them (like testing any other fuse) you will know--if either or both is blown--the convergence IC got them.
I have start to finish, step by step instructions and photos of the fuses etc----If you or someone you know can solder and is handy--you may be able to do the repair yourself.
If not, shops usually charge 300-400 for this kind of repair in this set.
LET ME KNOW IF YOU NEED ANY ADVICE or help.
Regards, SD TECH
Oct 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My tv is showing a double picture in red
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence on kdp-65ws550
Good Day, s_d_duncan;
The board for this 2001 Model is no longer available. Now, if you can solder, you can repair yourself. The parts you will need are two STK 392-570 (HIC), convergence IC's, part number 270P150010.
If you can't replace yourself, please call an authorized service center to give an estimate....
Good Luck, big IRISH.
Aug 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convergence??
e-mail me at networks@q.com and get me the chassis number see in the back of your tv under model number maybe chassis number
Apr 17, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
Remove the front grill. There are 2 screws on each corner accesable from the rear and 2 screws inside the front door. Push down on the grill and it will unsnap. Remove the pressboard coverplate . You should see the convergence board, it is about 12" long with a big aluminum heat sink. The board can be removed by pressing on the tabs that hold it down. Be sure to mark and unplug the molex connectors from the board. One of the connectors has to be unplugged from the chassis because it is fixed to the board. Once removed you can easily get to the IC`s mounted to the heat sink. Check for any burned resistors near the IC`s.( 2.2 ohm likes to burn) The convergence can be done through the customer menu using the remote. There is no special formatting necessary. Use the number pad to navagate and the select key to change red & blue.
Nov 06, 2007 | JVC AV-48WP74 48" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
