Question about JVC XL-SV22 CD Player
PLAYS CDG'S .SOUND'S FINE. SCREEN IS FULL OF STATIC AND HARD TO READ.REPLACED A-B SWITCH (I USE TWO PLAYERS).CHECKED AV CABLES.NO RESULTS!
2 Suggested Answers
  • 45 Answers
SOURCE: My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Posted on Jan 02, 2010
Eclipse avn 5435 deck plays fine but once in a blue moon no sound comes from it. Only using rca on unit, gps works fine. I unplug all connectors and then works fine.
Jess, do a wiggle test on cables when you have volume, wiggle wires one at a time to see if sound goes out or static.
press the helpful button
Feb 07, 2016 | RCA Car Audio & Video
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
My Super Nintendo plays with a yellowish tinted screen.
Well I think that the capacitors are causing the screen to be a yellow color then.
Apr 30, 2012 | Nintendo Super NES Console
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
I HAVE A NINTENDO NES IT PLAYS FINE IF SOMETHING BUMPS THE AV CABLE THE SCREEN GOES BLURRY AND WE HAVE TO TWIST THE CONNECTION TO THE NINTENDO TO GET THE SCREEN RIGHT BUT IT DOESNT LAST LONG WHAT CAN I DO
Not so sure, I still have mine, but it is messed up. What I did is i went out and bought a FC Twin. Its a system that can play NES and SNES games. It is so cool and easier. You could try to get an FC Twin or go online and buy a new cord. Hope that helps.
Jan 19, 2010 | Nintendo NES Console
Dvd player plays dvd but the screen only shows lines & the audio is fine.
Sounds like your av cables may need to be replaced or the DVD is bad. Check that the cables are in the correct ports coming from the DVD player to your television and that the cablesd have also been placed in the correct postitions.
Good luck
Nov 11, 2009 | Drive Mobile Entertainment MOBILE VIDEO 7...
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
JVC XL-SV22 CD Player Logo
41 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
