Question about Epson Aculaser C1100 Printer
Paper stuck in fuser.
A sliver of paper is stuck in the fuser. Can't get it out with tweezers. Epson say remove and replace fuser to enable clearing the blockage. How to do the removal and re-installation? What steps?
  • Epson Master
  • 691 Answers
It's fairly straight forward but you may find a service manual handy before you start. Get one HERE.
Posted on Jun 28, 2008
  • Inky Fingers
    Inky Fingers Jun 28, 2008
    Get the service manual HERE. Make sure the machine is off and has been for about 20 minutes before you start, as the fuser gets hot and will easily burn you when you start poking around in it.
    Make sure you do NOT gouge the surface of the orange rollers in the fuser. If you do, you'll have to buy a new fuser.
Paper stuck in feed slot
Try running in reverse. If that doesn't help try clearing as much as you can using tweezers. Last option soak the stuck paper with excessive amount of lubricant, it will loosen and soften the blockage and should clear out
Aug 09, 2013 | Epson EPS1200X Shredder
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Hpllaser jet 1200 paper stuck in the back I had try to pull it but I can barely see it there, i can't see it from the front
You might use a tweezers and try to pull out the paper. The paper is stuck by a sensor, and if you can clear that sensor, the machine will start up, and transport the rest of the paper out. Be carefull and try not to hurt the fusing rollers, while picking with the tweezers.
If it's no good, you have to disassemble
the fuser-unit and remove the paper, or in worst case, replace the fuser unit..
May 10, 2012 | HP LaserJet 1200n Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
I have some small pieces of paper stuck in the fuser unit from a sheet that got stuck - how do i get them out as I cannot see them?
Start to dismantling it untill you are able to see the paper and then with tweezers remove the paper carefully
May 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Paper jam stuck on
Just to make sure, have you opened it all up, removed the ink/toner and inspected everything?
If you've already done that, try unplugging the unit from the wall power for 1 minute, and then plug it back in, some printers will not clear until a power cycle has been performed.
Dec 18, 2008 | Sharp AL-1661CS All-In-One Laser Printer
Paper jam in Epson printer CX6000. I mistakenly left the bottom paper tray clossed while printing . Three pages jammed.I got two out; part of the third is stuck inside the printer. I can see a little bit...
from the inside of the printer , remove image ctg and slowly push a file folder through the fuser exit and remove the remaining scrap paper do not force !
Apr 19, 2008 | Office Equipment & Supplies
Paper stuck in roller
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Mar 31, 2008 | Brother HL-2040 Laser Printer
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Epson Aculaser C1100 Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
