Question about Zebra Z4M Printer
Hi, I am having some problem with a Zebra Z4M Plus Printer. The device is printing, but almost half of the label does not print (there is a straight line, and from this line, nothing is printed). I am using Zebra Designer. I also tried other softwares, and it is always the same. I also tried to print some text from notepad, and I also have the same result. How can I get a full label ? What could cause this problem ? If it helps, I can post a picture of the result I have on the labels. Thank you very much in advance !
  • 96 Answers
Check for missing teeth on the main drive belt.
Posted on Nov 21, 2010
2 Suggested Answers
SOURCE: Zebra Z4M Plus
this is a color printer or not
Posted on Oct 03, 2007
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Zebra Z4M plus printing an extra label
Restore factory defaults. If this doesn't sort it out, get back to me and I should be able to point you towards the right solution.
Mar 31, 2009 | Zebra Z4M Printer
Zebra Z4M Communication
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 27, 2009 | Zebra Z4M Printer
My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Nov 02, 2008 | Zebra Z4M Printer
Zebra Z4M
Turn the printer off. Shut off your software. Turn the printer on. Restart your software. The software will reset your label forms.
Jun 17, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4M Printer Logo
348 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
