Question about Alpine MRV-1507 Car Audio Amplifier
Mrv1507 power light blinks red..
Ya i have my amp on 2ohms two channel.. the power light blinks red the whole time plays kinda weak but it has 13.6 volts running into the amp...
  • 113 Answers
Also try checking ur ground wire to the amplifer
Posted on Jun 18, 2008
  • 29 Answers
Your speakers probably are made for 6 or 8 ohms. to check, take out any of the speakers and read the back for the ohm rating, if it is more ohms, you need a more powerful amp.
SONY KDL-52W5500 red light blinking 13 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Sony KDL-52W5500 52 inch Multi-System Full...
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
Will the amp play 2 ohm speakers
If your amp has ability to play 2ohms, then it will play. It will play even it dosn't have the provision. It might cause damage to the audio output at certain level if volume level is increased. My advice is to check your amp. or read the user mannual for perfact usage. Thanks
May 16, 2010 | Krell Showcase 5 5-Channel Amplifier
How do i wire the directed d600 2ohms stable
if youre subs are double coil the spkrs should have two sets of connections behind put red to red black to black that will give you the power you will need plus bridge it to youre amp for 1-2ohms continous power....make sure youre amp says continous power at 1-2ohms if it says in the manuel not stable it will just cut on and off at its peak because of over heating
Feb 21, 2010 | Directed Electronics D600 Car Amp
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
The Amp Power Light Coming ON and staying red.
Your amplifier are on protection mode,maybe the audio amplifier IC´s are in bad conditions
Sep 02, 2008 | Alpine MRV-1507 Car Audio Amplifier
Car Audio & Video Logo
186 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
