Question about Just Wireless Swivel Vehicle Charger
I have a Just Wireless swiviel charger with changeable phone connectors Sku NO. 03212. I was wondering if there was a connector for a mini usb port for this charger?
2 Suggested Answers
SOURCE: What type of fuse does my just wireless car
It uses a mini 2Amp cartridge fuse, as a workaround, one may simply use a single strand of very thin wire... or even a very thin strip of aluminium foil wound onto the Body of the fuse.
Posted on Feb 08, 2010
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
I don't have money for a new charger.... Watch
Chargers can be bought mostly though Amazon.com. If you can find them, you can search through the prices of cheap, replacement chargers. If your device has a common USB connector (I.e. type a, type b, micro a, micro b, mini a, mini b) you can find a generic substitute to similar plugs. Even my PSP and Kindle has had similar troubles because USB chargers seem to have a glitchy lifespan. Make sure to not mess up the system's charge port, my DS's port seems to differ from other USB chargers(Type B).
Jun 15, 2013 | Video Game Consoles & Games
Need a New Charger for VL-567K Digital Media Player
I have good news for you, the player charges from the USB port, and it's a very common standard. If you have the USB cable to download music/video from your computer, then you can also use the same cable to charge the player (from your computer). Also, the connector is called a "mini-B". If you go to your local electronics store, you can ask for a charger for a 'mini-B' USB device, and they'll probably have one. Look at some of the 'universal' chargers available, and compare with the mini-B plug on the end of your cable; it will probably have one just like that. If you can find a charger that has a plug that shape... it's going to work. The manufacturers have got together to reduce the proliferation of different charging devices, and are standardising on USB connectors wherever they can.
If you want to buy one online, search for "mini-B charger" and you should be good.
Oh, here's another thought; do you have a power converter for your car? Does it have a USB socket on it? That's for charging USB devices like yours - you can use your regular USB cable to charge your player!
Feb 21, 2011 | Visual Land VL-567K Digital Media Player
How do you get pictures on to your computer if you dont have a memory-card inserted?
your camera should have come with a cable that plugs into a usb port on the computer andplugs into something like one of these on the camera
usb-5pin-mini-m.jpg usb-5pin-mini-f.jpg 5-pin male mini connector, replaces B connector 5-pin mini female connector, used on most new Cameras, GPS Units, Cell Phones, Mini Hubs, Mini Hard Drives, Harmony Remotes, etc usb-pin-mini-m.jpg usb-pin-mini-f.jpg 4-pin mini male connector, replaces B connector 4-pin mini female connector, used on many older cameras; Olympus, Sony, Minolta, Kodak and Epson usb-nikon-m.jpg
Oct 17, 2009 | Cameras
Where to get in car charger for evesham 7211
Hi.
I just bought an in-car charger for the 7211 on ebay.
It is 5v with a 2amp flow.
It's not for the mini-USB port on the side but for the dc input hole on the other side.
I've just plugged it into my laptop via the mini-USB port to see if it will charge that way but it doesn't seem to be doing.
Hope this helps.
Aug 09, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Motorola krzr won't recharge.
The charger socket is soldered directly to the main board - if it's just the solder joints that have cracked, then a decently equipped mobile phone repair place should be able to resolder it - if it's actually ripped the copper traces off the board, then it's not really practical to repair it.
Since I happened to have a K1 in bits, here is a photo of the connector - it's normally attached quite firmly to the main PCB.
May 16, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Where is the usb port on this phone
http://nextelonline.nextel.com/NASApp/onlinestore/en/Action/OSBrowseAccessoriesDetail?PHONE_ID=I880G&categoryRefName=Data+%26+Connectivity
solution to this problem is that the USB is on the connector
its an accessory
-->pt_accessories_en.gif Data & Connectivity for the i880 by Motorola (Choose a different phone) spacer.gif Motorola USB Charging Data Cable - Item # NNTN5405 nntn5405_l.gif Easily link your phone to the USB connector of a computer or PDA, use your phone as a wireless modem and more. The cable also features an integrated charging port so the phone can be charged while simultaneously performing data operations. The charging port can be used with compatible standard, rapid and vehicle power chargers.
Jan 24, 2009 | Motorola Mobility i880 Cellular Phone
Just Wireless Swivel Vehicle Charger Logo
90 people viewed this question
Top Just Wireless Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Just Wireless Cell Phone Expert? Answer questions, earn points and help others
