Question about Canon MP560 All-In-One InkJet Printer
I have a Canon MP470 printer. I used an Office Depot to replace the colored cartridge, but it still shows a low level. How do I reset it Tom O'Hanlon
  • tomohanlon Nov 12, 2010
    No- it still shows the color ink level as low, but now I didn't even get a black imaga
    Just thought I'd let you know: I did two cleans, two deep cleans, nozzel checks and printed test sheets. I tried undoing the power and hit the stop/reset button.
    While the black read good, the color still read low.
    It deteriorated from to where I could get some color, the black stopped working.
    This was when I said "to hell with it" and went to the store and bought new CANON black and color cartridges and threw the others away.
    The printer now shows both cartridges as full and I'm getting good prints again.
    Tom
  • 340 Answers
To reset your printer you will need to unplug it from the back of the power source and leave it out for about 30-60 seconds. Plug it back in and you should be reset. Let me know if you need further assistance.
Lori
Posted on Nov 12, 2010
  • 1 more comment
  • Lori Langley Nov 12, 2010
    ok, locate the stop/reset button, hold this down for about 5 seconds or so and then release. This will disable the message that you are receiving about the low ink levels. Please let me know if it works once you have completed this step, if not we will troubleshoot further from there. Thanks
    Try this as well...
    Clean The Print Head Nozzles (Windows)
    The following contains instructions to check the nozzles for poor print quality and perform print head nozzle cleanings. If print results are faint or streaks are printed, the print head nozzles may be clogged. To improve print quality, perform print head cleanings or print head deep cleanings.
    Caution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
    Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
    Print a Nozzle Check Pattern
    1. Confirm that the printer is connected to the computer and the printer is turned on.
    2. Complete or cancel any print jobs in progress.
    3. Open the Printers folder.
      - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
      - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
      - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
      - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
    4. Right-click the printer icon and select 'Properties'.
    5. Click the Maintenance tab. (The Maintenance window opens.)
      Note: The layout varies depending on the printer and version of Windows you are using.
    6. Insert a piece of letter-sized plain paper in the paper tray.
      Select 'Nozzle Check'.
      Note: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
    7. When the confirming message is displayed, click 'OK'. (Nozzle Check printing will start.)
    8. Examine the Nozzle Check output.
    9. Determine whether the pattern is normal or not normal.
      When the output is normal
      Black ink: The grid pattern is regular without missing lines.
      Color ink: White streaks are not visible in the pattern.
      When the output is not normal
      If the following cases can be seen, perform the cleaning of the print head nozzles.
      No color is printed. (Nothing appears on the output.)
      There is any color which is not printed at all. (In the diagram below, black ink is not printed at all.)
      There are missing lines partially in the pattern for the black ink.
      There are white streaks in one of the color ink patterns.
      Click here if the pattern is normal.
      If the pattern is not normal, perform a Cleaning.
      Note: Perform this step first to clean the print head.
      If the pattern is not normal after two Cleanings, perform up to two Deep Cleanings of the print head.
      Caution: Cleaning consumes a certain amount of ink. Perform cleanings only when necessary.
    1. If the print head is performing as normal cleaning is not required. Click 'Exit' to return to the Maintenance window.
      Click 'OK' to finish and exit the Properties window.
      Perform a Cleaning of the print head nozzles:
    Caution: Cleaning consumes a certain amount of ink. Perform Cleaning only when necessary.
    Note: The pattern varies depending on the printer and version of Windows being used.
    1. Click 'Cleaning' to perform print head cleaning from the Pattern Check window and proceed to step 3 of the print head cleaning instructions. If the Pattern Check window is closed, skip this step and proceed to step 2.
      To perform a print head cleaning from the Maintenance window, click 'Cleaning'.
      When the confirming message is displayed, check the contents, and click 'OK'.
      Caution: Although the Nozzle Check window is displayed, do not perform any other operations until Cleaning is completed.. Cleaning will take about 40 seconds.
      Print a Nozzle Check Pattern and examine it.
      Perform Cleaning again if necessary.
      Note: If the pattern is still abnormal after two Cleanings, perform up to two Deep Cleanings.Perform Deep Cleaning of the print head
      Caution: Deep Cleaning consumes a larger amount of ink than normal Cleaning. Perform Deep Cleanings only when necessary.
    2. In the Maintenance window, click 'Deep Cleaning'.
      When the Deep Cleaning window is displayed, check the contents, and click 'Execute'.
      Note: Cleaning consumes a certain amount of ink. Performing Cleaning often, ink will be consumed quickly. Furthermore, Deep Cleaning consumes more ink than Cleaning; execute Deep Cleaning only if the nozzle condition does not improve even after Cleaning.
      By clicking Initial Check Items before clicking Print Check Pattern, you can see the specific confirmation items in Nozzle Check.
      When the confirmation window is displayed, click 'OK'.
      Do not perform any other operations until cleaning is completed.
      erform Deep Cleaning again if necessary.
      If the print quality does not improve, turn off the printer and let it sit for 24 hours or more, then perform Deep Cleaning again. The wait time may allow dried ink in clogged print head nozzles to liquify, and resolve the problem.
      If the print quality does not improve, replace the ink cartridge(s).
    Well, Im glad that you found the issue but sorry that you had to go through all of the hassle. I don't see why your office depot cartridges wouldnt work, thats actually what I use on a regular basis and have never had any issues. They are refurbished though, anyway its good to hear that its working for you. Did you speak to Office Depot about a refund?
What do I need to do when I install new ink cartridges to get the printer to stop showing that the ink is low or out ?
You will need to reset the software in most cases as the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jul 21, 2011 | Canon PIXMA MP470 All-in-One Printer
Low ink supply?
Hi There
This is a resetter program tools for the inks and much more.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 30, 2010 | Canon PIXMA MP470 All-in-One Printer
Low ink levels after replaceing with new ink cartridges
Hi
Dell's Inkjet, All-In-One Printers ... cartridges have a sensor in them that cannot be reset.
Sorry
Feb 03, 2010 | Dell 926 All-In-One InkJet Printer
Canon mx300 not recognize reffil cartridge color 51,
This cartridges has a memory chip and printer will recognized refill cartridges like empty.You can't reset the ink level on all Canon Pixma printers.Push resume button and hold it for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
If this not help there is a minimum chance your cartridge is failed electrically and printer not recognized.In this case replace the cartridge.
Nov 18, 2009 | Canon MX300 Office All-In-One Printer
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP560 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
