Question about Casio Edifice EF-509D-5A Chronograph watch Watches Watch for Men
The second wont move, but it was moving this morning until i pressed soemthing, the other second ahnd at the bottom the square one is still working fine its just the red second hand that isnt working, thanks in advance
  • 2,334 Answers
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Posted on Nov 16, 2010
Operating instructions for a Sekonda 3850
Let the 3 buttons on the left hand side be labelled A, B and C from top to bottom.
Hold C for 3 second until it beeps and display flashed.
Press B to move to whatever you need changing (e.g. hour, day, area)
Press A to change.
Press B to move to the next thing to change or press C once to exit.
May 28, 2012 | Watches
I need to reset the time
Not sure if all Casios are the same but mine works like this.
Push bottom left button 3 times until Seconds digits flash. Adjust Seconds by pushing or holding in bottom right button. Push in top left button to move to Hours ( will flash } Adjust as for Seconds.
Push in top left button to move to Minutes, adjust then move on to Date, etc.
Push bottom left button at any time to return to normal. Good luck!
Apr 02, 2011 | Casio Watches
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
Help needd to find out how ro set Alarm on my Bulova Millennia 98A48. A users guide would be appreciated. I have lost mine.
Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
I have a spare set of instructions if required.
Aug 07, 2010 | Bulova Millennia With Vibra-Alarm 98A48...
The second hand on my chronograph will not index properly when reset
Try this or some variation as it worked with my new Wenger Chronograph.
Pull the crown out to the first position (for changing the date) and press the top button - one of the hands - either the big second hand, the little minute hand, or the little tenth of seconds hand - should move one notch. Keep pressing until it reaches the desired position. Now press the bottom button, same process. Pull the crown all the way out and press the top button, same process. Then if that still hasn't solved it, crown all the way out and press the bottom button. Each position should correspond to a hand, and each press should move it one notch. When settled, push the crown all the way in and operate it normally.
Be careful not to press buttons when changing the date or time, and don't bang or shake the watch too hard while using the chrono. Also, don't play with the buttons or press them one after the other too quickly.
Oct 30, 2009 | Swiss Army Wenger Wenger watch
Trying to set time on nike watch
1. Press the bottom left button(MODE) to put on Time mode.
2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
5. Press the LIGHT button to finish.
Mar 13, 2009 | Nike Watches
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Tissot PRS 200 cannot reset counter hand (the counter stuck especially in the morning)
The owners manual mentions how to fix this but the instructions are not 100% clear. You can download the PRS200 manual here:
http://www.tissot.ch/data/usersmanual/134-en.pdf
Each of the 3 chrono hands are reset separately. Unscrew the crown and pull it all the way out (2 stops out). Press button A (top right) as many times as necessary until the hand is on the 30. Each press moves the hand one tick so you may need to press it several times.
Next push in the crown one click.
Press button B (bottom right) as many times as necessary to advance the 60 second hand to 12'oclock.
Press button A to advance the 1/10th hand to 0.
The part I did not get at first is the fact that you need to press the A and B buttons several times to advance each hand 1 tick at a time until they are all pointing to 12'oclock.
Oct 22, 2007 | Raymond Weil W1
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Casio Edifice EF-509D-5A Chronograph watch Watches Watch for Men Logo
682 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
