I have a sc 101error exposure lamp. How do I reset or fix this on a ricoh 171
    Brigadier General:
  • 3,917 Answers
Thank you for contacting Fixya.com.
Sc101 means that the standard white level was not detected which indicates exposure lamp problem. Turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left. However when you first turn on your machine the scanner scans a white plate (you will find this plate under the glass or frame near the park position of the scanner .This error is preventing the scanner from seeing this plate exposure lamp not working, blocked scanner, or more likely a dirty white plate.
Remove the glass, get a mirror and try to find the plate and then clean it. When you turn on machine the scanner will try to scan this white plate.
For original size your machine may use paper size sensors that look like small black boxes with two black eyes , make sure these eyes are clean.
Please get back to us if you have any further query.
Have a nice day.
Posted on Nov 12, 2010
Sc 101 ricoh mpc305
1. Check and clean the scanner mirror(s) and scanner lens.
2. Check and clean the shading plate.
3. Replace the exposure lamp.
4. Replace the lamp stabilizer.
5. Replace the scanner mirror(s) or scanner lens.
6. Replace the SBU.
Mar 03, 2017 | Ricoh Office Equipment & Supplies
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Sc 194 code in ricoh copier what is problem
Dear
Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate
Thanks.
Feb 22, 2015 | Ricoh Office Equipment & Supplies
Sc 101 sc101
Exposure lamp error.Verify the exposure lamp and the expo lamp thermistor.
Jan 09, 2014 | Ricoh Aficio 2015 Copier
Hi all I have ricoh af 2045 giving sc 823 plz help with ???
check exposure lamp cable a nd lamp if not then reset your machine
Jul 13, 2013 | Office Equipment & Supplies
Sc 101
there's a number of lens in the scanner board, can u tell where is that lens is. if it is really the lens misposition check all the screws there could be a loosen one, but usually if lens are place into the unit again once it is pull out for replacement it will automatically place in its original position.
you can try these:
SC-101 for ricoh (complicated to fix)
- exposure lamp defective
- check SIFB
- clean all the sensor in scanner board
- check the Power supply for loose contact
Mar 04, 2013 | Ricoh Office Equipment & Supplies
Ricoh afi 1022cio error code 101 need reset thank
Exposure Lamp Error
Symptom: The standard while level was not detected properly when scanning the white plate.
Possible Cause: • Exposure lamp defective
• Exposure lamp stabilizer defective
• Exposure lamp connector defective
• Dirty scanner mirror or scanner mirror
out of position
• SBU board defective
• SBU connector defective
• Lens block out of position
• Incorrect position or width of white
plate scanning (? SP4-015)
Jan 17, 2011 | Ricoh Aficio 1022 All-In-One Laser Printer
My machine is ricoh FT 4220. error 11 or E1
E101: Exposure lamp error
1- check the Exposure lamp if it damage replace it .
2- check the Exposure lamp fuse ( located in scanner )
3- check the Exposure harness .
and after you solve your problem you must
Enter SP5-810 (SC code reset) and press the Enter key to reset the code
Jan 04, 2011 | Ricoh FT3713 Copier
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
jasbo
jasbo
