Question about Frigidaire Washing Machines
My washing machine stopped in the middle of a cycle and left my clothes soaking wet. Now none of the other cycles will work either.
    President:
  • 1,654 Answers
The timer or control board has gone out on you.
Posted on Nov 13, 2010
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Why does my brand new ( just got it today) kenmore washing machine stop in the middle of the cycle?? the clothes are still soaking wet!!!
Contact the place you bought it. Dont even try to guess a new unit should work without question. There is a year warrenty. Just return it.
Jul 17, 2009 | Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
There is an odor after the cloths are washed
You have a build up inside the washer. When it gets wet, it smells. When it dries out, the smell goes away. To solve this, first use 3 tables (one package) of AhFresh, or washer magic, or whirlaway, set washer on tub clean cycle if you have that cycle, or if not, use the hottest and longest cycle you have. Run cycle with no clothes. Now, to prevent this from reoccurring, make sure you use only ONE TABLESPOON of detergent or less per cycle, and only ONE TEASPOON of fabric softener per cycle if you use it. These washers use only a very small amount of water per cycle, and you must adjust additives accordingly to prevent odor and other problems. This is the number one problem people have with their front loading machines, and is 100% preventable! NOTE: You probably have soap residue left in your clothes. Try washing them with no soap once with to see if you get any suds in washer. You should see none if there isn't any remaining residue. Bath towels are usually just used to soak up clean water off your clean body. Don't use soap when you wash them. They don't need it.
Oct 14, 2008 | LG Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
