Televison & Video Logo
Posted on Nov 12, 2010
When I switch on my Logik TV, the screen now says "NO SERVICES - select the Services Set up menu" But there is no such menu anywhere, and I cannot exit this screen! Help, please IAN
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1172
Points
This also happened to me, but the problem is that your attena cable has accidentally dropped out of your TV. Slot it back in and then auto tune again. Hope that helps!
  • brad lacey Feb 12, 2011
    I have the same problem, have you found out how to access the services setup menu?
    Brad
  • Anonymous Jan 20, 2012
    this is happening to me also i have tried numerous occasions of disconnecting and reconnecting but still says service setup but there is no such button, did anyone resolve this issue please
    thanx lesley
How do I set up caller Id on my hisense tv thru at&t cable source?
Hello, Karen -
I hope I am correct in assuming the AT&T cable remote control is already synced with your TV.
Also, I hope you are asking about a landline phone with AT&T as the service provider.
If so . . .
With your AT&T remote control, press MENU.
You then should see a side bar with a list starting with GUIDE.
Press 9-8-0-0. which should bring you to the guide listing for PHONE SERVICES. Press OK.
On the PHONE SERVICES screen press OK
Your land line phone number should be listed on the PHONE SERVICES MAIN MENU screen,
One choice on the PHONE SERVICE MAIN MENU will be one for SETTINGS. Move down to highlight CHANGE SETTINGS FOR MESSAGE INDICATOR AND CALLER ID DISPLAY. Press OK.
Follow the on-screen directions to select DISLAY MESSAGE INDICATOR and be sure to choose DONE to save the setting,
After saving the CALLER ID setting, just press the EXIT button on the AT&T remote control and then choose to power the remote control and TV off or choose a channel you wish to watch.
Best wishes,
tip
How to sync Gmail contacts with your mobile phone
<p>Google Sync is needed to make your calendar and synchronize Gmail contacts with the device. However, Google Sync is not compatible with all devices. Google Sync for iPhone, Blackberry, Windows Mobile and Nokia E series and N series devices. You must have iPhone OS 3.0 or newer version of Google Sync. By configuring this feature, Google Sync will update the phonebook contacts from the device to your Gmail contacts. Because Google Sync is a two-way service, you can save time by adjusting a single platform, such as telephone or Gmail account. <br /> <p><br /> <p>Windows Mobile <br /> <p>1. Choose the Active Sync on the Home screen and select "Set up your device." <br /> <p><br /> <p>2. "m.google.com" type under the "Server Address" field and then check the option "This server requires an encrypted connection" box. <br /> <p><br /> <p>3. Log into your Gmail account by entering your data. <br /> <p><br /> <p>4. Select "Next", enter your full address and password in the "User Name" and "Password" and select "Next." <br /> <p><br /> <p>5. Check "Contacts", "Calendar" or "Email" check box, depending on the features you want to sync with your device, then select "Finish". <br /> <p><br /> <p>Blackberry <br /> <p>1. Visit the following page using your Blackberry browser: http://m.google.com/sync <br /> <p><br /> <p>2. Select "Download Google Sync" link by selecting the BlackBerry menu button, then select "Get Link". <br /> <p><br /> <p>3. Select "Download" is directed to a download page. Google Sync icon appears on your home screen. <br /> <p><br /> <p>4. Select the icon, move the cursor to the login section, enter your full Gmail address and password fields and click "Login". You are redirected to a welcome screen. <br /> <p><br /> <p>5. Read the summary information on the welcome screen and choose "Sync Now" button at the bottom of the Welcome screen. Standard Google Calendar and Contacts sync synchronizes automatically. <br /> <p><br /> <p>Apple Devices <br /> <p>1. Go to the homepage of the phone screen and then open the Settings application. <br /> <p><br /> <p>2. Select "Mail, Contacts, and Calendars" and select "Add Account". <br /> <p><br /> <p>3. Choose "Microsoft Exchange", and then all your e-mail account on Google's "Mail" field. Do not enter information into the "Domain" field. <br /> <p><br /> <p>4. Enter the email address from Google / Gmail account and password into the "User Name" and "Password" and select "Next." <br /> <p><br /> <p>5. Select "Cancel" when prompted by the message dialog "Unable to Verify Certificate". <br /> <p>6. Type "m.google.com" in the "Server" and select "Next." <br /> <p><br /> <p>7. Enable synchronization of Google services such as "On" next to "mail", "Calendar" or "Contacts." <br /> <p><br /> <p>8. Select "Delete existing contacts" if you just want to synchronize my contact group. " <br />
on Aug 18, 2011 • Google Gmail
The movies want play
  1. Test your Internet Connection
    1. From the PS3 main menu, navigate to Settings.
      • If you're not already at the main menu, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Select Network Settings.
    3. Select Internet Connection, and verify it is set to Enabled. If it's Disabled, make sure to select Enable.
    4. Select Internet Connection Test.
      • If you are able to connect to the Internet, check your date and time settings.
      • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Refresh your Netflix Iogin information
    1. Begin from the PS3 Home Screen.
      • If you're not already at the home screen, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Navigate to the TV/Video Services section and highlight Netflix.
    3. Press X.
    4. Immediately after pressing X, press and hold both Start and Select and continue to hold them down until a message appears asking Do you want to reset your Netflix settings and re-register?
    5. Select Yes.
    6. Enter your Netflix email address and password.
  3. Reinstall the Netflix application
    1. From the PS3 Home Screen, navigate to the TV/Video Services section and highlight Netflix.
    2. Press the Triangle button on the Playstation controller.
    3. Select Delete.
    4. Select Yes.
    5. Download the Netflix application to your PS3.
    6. From the PS3 home screen, navigate to the TV/Video Services section and select the Netflix icon.
    7. Select Yes on the Are you a member of Netflix? screen.
      • You may be prompted to sign in to your PlayStation Network (PSN) account first.
    8. Enter your Netflix email address and password.
  4. Troubleshoot your Internet Connection
Oct 22, 2013 • Netflix
I have a new Logik TV L19D1GB10, but am stuck at "No Services" "Select the Services Set-up menu to add new services". - I can't find the latter. It is supposed to be...
Welcome to Fixya
Looks like you have no input source connected to the TV. You need an aerial or some type of pay TV service like satellite or cable. You could also try a DVD player. In each case, you have to select the proper input with the set's remote.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
6helpful
3answers
GPRS not subscribed? T-mobile help?
must follow exactly for full help topics i offer a cd with all settings for every provider along with hundreds of java games wallpapers and mp3 ringtones. if interested submit 10 us dollars to [email protected]. will send as soon as payment is eceived in padded envelope first class mail. SMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap SMS on the Messages menu. 3.) Tap SMS settings on the SMS menu. 4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting up at this time for SMS messaging. 5.) Tap Profile settings on the SIM1(2) message settings menu. 6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the screen. 7.) You should be on the Profile name menu with the name field already highlighted. Go ahead and tap the Edit button at the bottom of the screen. 8.) Tap in the following text between the quotes in the Profile name editor: ?T-Mobile? Next tap the Options button at the bottom of the screen. Next tap the Done button. You should be back on the Profile name menu with the new name. 9.) Tap the area below the profile name. The top of the menu should change to read SC address and the bottom of the screen should show a numeral keyboard. Tap in the following text between the quotes in the SC address editor: ?+12063130004? Next tap the OK button at the bottom of the screen. 10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. You are done setting up SMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test SMS messaging by sending yourself a text message, or continue with other setup of the phone. The next sections will show you how to set up MMS messaging as well as an internet connection if you are paying for T-Mobile?s internet access services. One note about internet services, as a T-Mobileweb customer you can get full access to anywhere on the internet if you install & use a Java based web browser such as Opera Mini instead of the internal browser of the phone, and as of this writing you don?t need to be on their much more expensive internet plan, the simple $5.99 T-MobileWeb plan will work! You can get Opera Mini here => MASTER Download List Our next step will be to set up the data connections you will need to use. If you are not going to use the internet or will only be accessing T-Mobile?s T-Zones, then you only need to set up the first data account service we will name T-Mo MMS, otherwise if you want to access the full experience of the internet, please set up both data account service connections outlined in the next section. Don?t worry if at any time you exit from one of the menus and find yourself back at the slidelock screen, simply just slide unlock the phone and continue from where you last left off! Data Account Services: 1.) Setting up regular data account services for MMS & T-Zones access. 2.) From the main screen tap the Service icon. 3.) Tap Data account on the Services menu. 4.) Tap GPRS on the Data account menu. 5.) Choose any of the profiles in the current list and tap the button. 6.) You are now on the Edit screen. 7.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 8.) Tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 9.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 10.) Tap in the following text between the quotes ?wap.voicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 11.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of the screen. You should now be on the Services menu. 15.) Tap WAP on the Services menu. 16.) Tap Settings on the Internet services menu. 17.) Tap Edit profile on the Settings menu. 18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up at this time for MMS messaging. 19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 20.) Tap on Profile 8. Tap Edit profile. 21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 22.) Clear the current text, then tap in the following text between the quotes ?T-Zones? Tap the Options button at the bottom of the screen. Tap the Done button. 23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 24.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?wap.myvoicestream.com? Tap the Options button at the bottom of the screen. Tap the Done button. 25.) Tap the area below Data account, then tap Select at the bottom of the screen. 26.) Tap GPRS on the Data account menu. 27.) Scroll down the list until you come to T-Mo MMS, the data account set up earlier under the Data Account Services section. Tap on T-Mo MMS to select it. 28.) Tap the area below Connection type, then tap Select at the bottom of the screen. 29.) Tap on HTTP, then tap on OK at the bottom of the screen. 30.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 31.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. 32.) Tap the OK button on the bottom of the screen. 33.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 34.) Next tap the Done button at the bottom of the screen. 35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 37.) Tap the On/Off button once to exit to the main screen. 38.) If you ONLY want MMS and T-Zones access without the full internet connection, you can now skip down to the MMS Messaging section and continue setting up MMS messaging; otherwise continue below at step 39 to set up a second data account service which will be used for your internet connection. 39.) Setting up a 2nd data account service for full internet access. 40.) Tap the Service icon on the main menu. 41.) Tap Data account on the Services menu. 42.) Tap GPRS on the Data account menu. 43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the button. The profile right under it would be fine. 44.) You are now on the Edit screen. 45.) Tap the area just below Account name, then tap Edit at the bottom of the screen. 46.) Tap in the following text between the quotes ?T-Mo Internet? Tap the Options button at the bottom of the screen. Tap the Done button. 47.) Tap the area just below APN, then tap the Edit button at the bottom of the screen. 48.) Tap in the following text between the quotes ?epc.tmobile.com? Tap the Options button at the bottom of the screen. Tap the Done button. 49.) Both the User name & Password areas should remain BLANK. If they are not blank, then tap on each one and Clear what is in them so they are both blank. 50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the arrows to move the selection so it has Secure, then tap Done. 51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 52.) Now that you have set up a second account service for internet use we can adjust the WAP settings for T-Zone to use this faster and less restricted internet gateway. 53.) Tap the On/Off button once to return to the main menu. 54.) Tap the Service icon on the main menu. 55.) Tap WAP on the Services menu. 56.) Tap Settings on the Internet services menu. 57.) Tap Edit profile on the Settings menu. 58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up at this time for SMS messaging. 59.) Tap T-Zones on the Select profile menu. 60.) Tap Edit profile on the T-Zones menu. 61.) Tap the area below Data account on the Edit profile menu, then tap the Select button at the bottom of the screen. 62.) Tap GPRS on the Data account menu. 63.) Find and tap on T-Mo Internet on the Data account menu. 64.) Tap the Done button on the bottom of the Edit profile menu. 65.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Zones profile. 67.) Tap the On/Off button once to exit to the main screen. 68.) Continue below with setting up MMS messaging. MMS Messaging: 1.) From the main screen tap the SMS Text icon. 2.) Tap MMS on the Messages menu. 3.) Tap MMS settings on the MMS menu. 4.) Tap Server profile on the MMS settings menu. 5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up at this time for MMS messaging. 6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but profile 8 is usually the first not already filled. 7.) Tap on Profile 8. Tap Edit profile. 8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen. 9.) Clear the current text, then tap in the following text between the quotes ?T-Mo MMS? Tap the Options button at the bottom of the screen. Tap the Done button. 10.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen. 11.) Clear the current text except for ?HTTP://?, then tap in the following text between the quotes after the HTTP:// ?216.155.174.84/servlets/mms? Tap the Options button at the bottom of the screen. Tap the Done button. 12.) Tap the area below Data account, then tap Select at the bottom of the screen. 13.) Tap GPRS on the Data account menu. 14.) Scroll down the list until you come to T-Mo MMS, the data account set up under the Data Account Services section. Tap on T-Mo MMS to select it. 15.) Tap the area below Connection type, then tap Select at the bottom of the screen. 16.) Tap on HTTP, then tap on OK at the bottom of the screen. 17.) Tap the area below Proxy address, use the numeric keyboard at the bottom of the screen to tap in the following numbers, ?216155165050?. The result should look like 216.155.165.050 under Proxy address. 18.) Tap the area below Proxy port, use the numeric keyboard again to tap in the following numbers ?8080? to replace the current 0 value. Then tap OK. 19.) The areas under both User name & Password should remain BLANK. If they are not blank, select each, and Edit them by clearing all text. 20.) Next tap the Done button at the bottom of the screen. 21.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen. 22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be taken back to the Select profile screen where a big green check mark will be beside the newly saved T-Mo MMS profile. You are done setting up MMS messaging for T-Mobile. You can continue to tap the Back button on the bottom of the screen until you exit out of all the menus to the main screen, or simply press the On/Off button once to get back to the main screen. At this point you can test MMS messaging by sending yourself a picture message. Internet Access: If all you want to use for internet surfing is the phone?s built-in browser, and you have set up the data account service for the internet in the earlier setup, then you are ready to surf the internet by simply tapping on Service from the main menu. Then tapping on WAP and using the various options to navigate the internet like Homepage, Input address, etc. However, this won?t provide as robust an internet experience as a Java based internet program such as Opera Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java program for browsing the internet, there is one more setting which must be changed prior to using the Java internet browser. Java Internet Settings: 1.) From the main menu tap on the Java icon. 2.) Tap Java settings from the Java menu. 3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile, which ever SIM you are currently setting up. 4.) Use the arrows to scroll the setting until T-Zones appears in the box. 5.) Tap the OK button at the bottom of the screen. Now you should be completely set up for SMS, MMS, as well for internet on the T-Mobile network if you have a T-Mobile internet plan!
3helpful
Cant get internet to work on my cect p168c i have tmobile
you have to follow this step by step. if youve tried this and it dont work i have no clue, i have set this up for several people on this site with no problems. as for the comment on uk if you will post this in a seperate help i wil try and help. it is limited to amount of text i can add. i have t mobile and these settings work for me. since you only said internet that is all i am posting.
“T-Mo MMS”
“wap.voicestream.com”
“T-Zones”
24.) Clear the current text except for “HTTP://”, then tap in the following text between the
“wap.myvoicestream.com”
of the screen.
“216155165050”. The result should look like 216.155.165.050
to tap in the following numbers “8080” to replace the current 0
value.
clearing all text.
“T-Mo Internet”
“epc.tmobile.com”
Internet Access:
If all you want to use for internet surfing is the phone’s built-in browser, and you have set up
won’t provide as robust an internet experience as a Java based internet program such as Opera
box.
Now you should be completely set up for internet on the T-Mobile network if you have a T-Mobile internet
plan!
3answers
Logik tv
What is the model?
Replacement owners manuals are generally very cheap through the service manual services displayed on this site. Google on "owners manual" for your model and maybe you'll get lucky.
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
