-   I have a rear proj. sony tv that the blue pic tube is out on. (per srvc guy). Where and how much would a replacement cost? also, how much is labor. I don't wanna get taken advantage of. Thanks.-   smurfetta13
Good Day;
A blue picture after it's been on for a bit is normally one of several things. The most common for your Sony is the CRT, tube, the second most common problem is the blue CRT 'IC'(chip). The IC is located is on the blue crt board.
The best way to determine this is to remove the speaker grill(on front of TV), then inner panel, the blue tube will be on your right hand side. Remove that little board at the end of the tube.THIS AFTER YOU HAVE UNPLUGGED THE POWER FROM THE WALL. Plug TV back in turn TV on. If TV comes on with picture and there is no blue in the picture, The tube is bad, if TV turns off it's the IC.
Good Luck, BI.
I just replaced the convergence chips on my Philips 60'' projection TV and forgot where all the...
(More)
I just replaced the convergence chips on my Philips 60'' projection TV and forgot where all the wires go? My Dad thinks he has it right, but the picture is red & blue & the captioning is shadowed. Can you please help?
toshiba 42" when i turn power on tv comes. my stay on for 10min or stay on for hrs.but just...
(More)
TOSHIBA 42" WHEN I TURN POWER ON TV COMES. MY STAY ON FOR 10MIN OR STAY ON FOR HRS.BUT JUST TURNS OFF BY ITSELF.THE LIGHT BLINKS.I HAVE TO UNPLUG IT.AND PLUG BACK IN SOME TIMES I HAVE TO DO THIS SERVERAL TIMES FOR IT TO COME BACK ON.ANY HELP?
have a sxrb sony keeps losing picture and sound for a few sec-min then coming back on. lite flashes...
(More)
have a sxrb sony keeps losing picture and sound for a few sec-min then coming back on. lite flashes green
When i press the power button, the television does not come on but power button on the television...
(More)
When i press the power button, the television does not come on but power button on the television turns blue like it is on. and when i press the button again to turn it off the button stays blue and dosent power it off, its supposed to turn red when it is off.
