Question about Sharp LC-42D43U 42 in. LCD HDTV
Colored lines running up and down - Sharp LC-42D43U 42 in. LCD HDTV
  • 335 Answers
LVDS cable is flawed or LCD T-Con board needs replacing or the panel is bad. You need to open the back cover to check and confirm which is causing the problem.. I can walk you throught it.. http://www.shopjimmy.com/
Posted on Nov 12, 2010
Colored lines down the tv
old tv. don't put anymore money in it. get you a nice flat screen. not work it being a projection. jmo
Oct 08, 2014 | Toshiba 42H81 42" Rear Projection...
Have sony model KdL 40S2000, now has colored thin lines going up and down on the left side. Anyone know the cause.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Color lines running down the screen
That can be caused by either the Tcon or the panel itself may have an issue. The TCon is most likely though. Your audio works correct right? I would try a new TCon you can get them from www.tvrepairworld.com
Jan 11, 2013 | Sharp LC32D62U 32 in. LCD HDTV
This is a new system, however, when I first hook up the system up, I got a good clear color picture, but no audio, just buzzing, I changed my wire connection around, and I got the volume and picture, but I...
i would hook it up via an optical cable for audio or left and right rca cable for audio and try and stick with components for the video should solve the problem. the no color means if you are using a component cable you have put them in wrong. the blue and green look alot alike ihave messed up before. also i did some research on this model. i have heard some people running into these problems no matter how they hooked it up. hdmi the way to go tho.
Mar 14, 2011 | Memorex MVD2016 DVD Player
Hp 2500l prints a dark line horizontal down each page. Can we clean drum at home?
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Dec 14, 2010 | HP Color LaserJet 2500L Laser Printer, up...
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Sharp LC-42D43U 42 in. LCD HDTV Logo
158 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
