Question about HP Compaq nc6000 Notebook
Ihave laptopnc6000 its light on then off fan alsoon but four orfive seclater it off please help me to solve this problem
  • 358 Answers
This is likely to be as a result of your processor over-heating, maybe because of your
environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself),
and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser,
and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it
works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the
other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped
behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the
environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Nov 12, 2010
How do I wire a light assembly,,,,my ex girlfriend toke it apart when she left...I have everything.need color codes.
See the link below and then enter the model number of your fan in the box. You should be able to retrieve the information you need from there:
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
Jul 17, 2015 | Hunter Dryers
I have a hitachi c21- f800snt 21" Ihave no
To release the child lock, you must have its remote control.
Oct 14, 2013 | Televison & Video
Sony kv 27542
Four blinks to Sony CRT based standard televisions are not due the fault to any fan, as there is no fan inside any CRT based Sony TVs. Four blinks denotes this. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Check for this fault. If you wish to get more http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. Blinking codes and faults to many televisions are described in detail.
Jun 27, 2013 | Televison & Video
My NEC VT676 fall in a problem when I power on today. The status light is blinking four times in red when power on. I have read its is fan error. Please tell me how I can solve it.
There are many fans. Some are blower fans. Some are exhaust fans. You will have to open the projector & check which one of them is not functioning. Replace the one which is not functioning. It is also likely that there may be some failure of components.
-sonsunny
Jul 09, 2011 | Office Equipment & Supplies
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
Using remote control and wall switch
think your out of luck. the switches need to be the same on both units to communicate
Jul 22, 2009 | Aloha Housewares (93645) Ceiling Fan
As soon as i connect the mains supply green light on front panel comes on then out then red front panel flashes four times then wait then four times etc...
Here is a HP/Compaq document to help you diagnose the issue:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=bph06788
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Compaq Computers & Internet
Thermostat wiring
First do not adjust the dip switches they are factory set to the parameters.
Second, W (usually white) is your furnace
O (usually orange) is your heat pump
G (green) indoor fan
R (red) 24 VAC
C (blue) Common 24VAC
Y (yellow) Condenser
May 05, 2009 | Heating & Cooling
S class stuck in park
Try this. Start engine, pump brake pedal four times, depress brake pedal and try selector again.
Apr 25, 2009 | 2002 Mercedes-Benz S-Class
Why does my Hampton Bay fan light goes on by itself
I had the same problem as well.....It turn out that there was interference from some other electronic device, garage door, microwave, digital phone etc etc etc who knows for sure. I removed the fan from the ceiling and pulled the small remote control box out, changed the code on the four tiny switches...changed the code on the remote control to match the control box...... Completely solved the problem with the lights. Hope this helps..
Dec 14, 2008 | Hampton Bay 24002 Ceiling Fan
HP Compaq nc6000 Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
