Question about Timex T158W Clock Radio
Forgot how to set time. Can set alarms and minutes/days/days of week, but have completely forgotten time moving backwards for a season. Love this little clock, but right now, it's a rubik's cube with an additude; THANKS!
  • 15,935 Answers
CLICK HERE for your user manual.
You can save or print it for further reference.
Setting the clock is inside. (page 6) as follows...
Setting Clock Time and Calendar
Important - While setting the time or calendar, if you do not press the appropriate buttons
(as explained below) within approximately 8 seconds, the display will stop flashing. If this
happens you must follow the instructions again from step 1.
Setting the Clock Time
1. Press and hold the Time Set Button until the display begins flashing.
2. Press the FWD/Month or REV/Date Button to select correct time. Remember to
set the correct AM or PM. The PM Indicator is located on the upper left side of the time
digits (there is no AM indicator).
3. Press the Time Set Button again to return the display to normal mode. You can also
allow the display to flash for approximately 8 seconds to return to normal mode.
Note: While setting the time, if you press and hold the FWD/Month or REV/Date
Button the minutes will begin counting at a moderate pace, then get faster. This will
assist you in easily setting the time quickly and accurately.
Thanks!!
Posted on Nov 12, 2010
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Mar 15, 2011 | Audio Players & Recorders
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
Can not change time!!
TO SET ALARM:
Good luck and please rate 4 thumbs up for the free answer
Apr 22, 2010 | SkyScan 86709 Atomic Wall Clock
I can't reset the time on my clock
TO SET ALARM:
Good Luck aqnd please rate 4 thumbs up for the free answer
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
Timex T158W Clock Radio Logo
138 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
