Question about Whirlpool LER5636P Electric Dryer
New dryer belt configeration
I am trying to put a new belt on my dryer but i can not figure out how to configure the belt on the tention pully. can you help?
MODEL - LER4634901 I BELIEVE A BELL MAY BE OFF OR POPPED OUT, AS THE DRIER HEATS UP BUT DOES NOT TURN THE INSIDE DRUN THAT HOLDS THE CLOTHES DOES NOT TURN AT ALL PREVNETING THE CLOTHES TO NOT DRY. CAN YOU ADVISE ME ETC,
Posted on Jun 30, 2008
    Genius:
  • 1,028 Answers
Loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Posted on Jun 18, 2008
Need to know where the tentioner pully goes to put the belt back on
Difficlut to specify as you did not indicate the make or model of your dryer, but usually the tensioner goes into slots on the machine base, and the belt holds the tensioner off of the interrupt/safety switch...
Feb 25, 2011 | Dryers
Serpintine belt routing for a 2002 dodge ram 1500 with a 5.9 l engine
this is farely easy to figure out from looking at your pullies. ribbed pullies normaly take the ribbed side of the belt and smooth pullies take the smooth side of the belt. i would start at the tentioner pully (which is smooth) the put the inside of the belt around the 2 nearest pullies and weave it alternating in and out of the rest of the pullies.
Jan 29, 2011 | Dodge Ram 1500 Cars & Trucks
Putting the belt back on this dryer
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 26, 2009 | Hotpoint Dryers
The belt broke drum won't turn
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Majic chef dryer rollers making noise. cannot figure how to get inside of dryer exposed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Magic Chef CYG4000AWW Gas Dryer
2000 isuzu rodeo removal and installation of serpentine belt
All u need to do is put a wrench on the tention pully and turn it clockwise... this will relive the tention take off the old belt ....put on new one. repeat relive pressure again ...slip it on pully... and relese tention..... done! :)
May 16, 2009 | 2000 Isuzu Rodeo
Change belt on electra 37527
Hi what you need to do is take front off the dryer take out old belt the new belt is then placed around the drum around the drive wheel and then under tention pully . thank you for useing fixya
RATE ME
Apr 15, 2009 | Dryers
How do i?
Apr 05, 2009 | Kenmore 63942 Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
Tention pulley or so i think
it goes in front of the motor,you'll see the slots in the cabinet under the motor,both side of the belt go under the pully and onto the motor pully-mike
Dec 14, 2008 | Kenmore 62602 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
