Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
FARMALL 460 HYDRAULIC PUMP, LOCATION AND REMOVAL INFORMATION? THANKS, NELSON
5 Suggested Answers
  • 10865 Answers
SOURCE: Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
Posted on Apr 15, 2009
  • 6 Answers
SOURCE: what kind of hydraulic fluid can i use in my
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Posted on Jan 06, 2010
  • 14 Answers
SOURCE: Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
Posted on Aug 17, 2010
  • 18 Answers
SOURCE: where are hydraulic fluid drain
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Posted on Mar 20, 2011
Where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
Jan 04, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where are hydraulic fluid drain plugs located on farmall 560
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Is hydraulic fluid really used for both the transmission and hydraulics in the international 460 also where do you fill it?
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Apr 28, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
I have powerful hydraulic action with my end
The relief valve may be by-passing, or your pump is cavitating..If you can hear a hissing... its the relief...if you hear whining or chuttering sounds... it is the pump cavitating.It sounds much like a power steering pump. Check your fluid level. **Note There may be water in the system if the oil is really milky looking, also from the cavitation of the pump which causes air in system. And then....Go from there or ask more.
Jan 11, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
654 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
