Question about Roper FEP320 Electric Kitchen Range
Roper electric stove model fep-320 oven knob won't turn past 200 degrees if forced makes buzzing sound?
SOURCE: Roper stove/oven range
need a solution for this problem
Posted on Sep 04, 2007
  • 3 Answers
SOURCE: my roper stove keeps clicking even when all knobs are off!!!
spilling water around spark control switches closed to burner control valves could cause that...may stop clicking in a day or so..or if on low flame setting the orfices on the burner head are carbon restricted? clean orfices with torchtip cleaners..
Posted on Jun 25, 2009
  • 149 Answers
SOURCE: Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Posted on Mar 27, 2010
muffteck
  • 202 Answers
SOURCE: I have a roper electric stove. When I turn the
dont use it it could kill you unplug and calll a appliance tech
ftw1952
  • 10319 Answers
SOURCE: We have a Roper model # FES340YW-2 electric stove,
bad thermo switch
Posted on Oct 30, 2010
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Theres no oven tempature listed. how do i work the oven part?
Get yourself a COOKING thermometer,like for checking syrup/candy temps,--put it in the oven,turn the knob to certain spots and give the oven time to heat.Take a reading and mark on the knob what the temp is in perm marker.
Mar 26, 2010 | Roper FEP310 Electric Kitchen Range
I have a model MER5755QAS. Oven/broiler not working right.
Sounds like you may be getting only 110v to unit. After unplugging, Check for any burnt wires around terminal block or around elements. Also first check if breaker may have half way tripped. Cut breaker for stove all the way off and then back on. The bake element may have partially tripped the 220v breaker thus only sending 110v to unit.
Oct 31, 2017 | Maytag MER5775Q Electric Kitchen Range
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Jan 19, 2007 | Roper FEP310 Electric Kitchen Range
Roper FEP320 Electric Kitchen Range Logo
121 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Jim Thurston
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
