Question about RCA P52830BL 52" Rear Projection Television
I have a rca model# P52830BL projection T.V. that has a convergence problem. I was wondering if i could fix it myself, the repair man here wants 350.00 just to look at it. Is it a coostly fix or can i do it? If so how? thanks alot
  • 1694 Answers
SOURCE: convergance circuit board
Convergence PCB probably not available....can you get me any #'s off the PCB or part # of STK IC or location # of convergence IC ??? ..................Should be worth fixing if I can get alittle more info....................T.
Note to mountain mom: You have a completely different
symptom ..............+ need service #.............
Try DVD ? all inputs ? cable box ? source to RF coax= on ch.3 ?..............................T.
Posted on Nov 19, 2007
skippy101
  • 143 Answers
you dont need a new board just replace convergence ics that would be the way to go will cost you under 75.00 if you do it your self if you take it in it will cost you 250-350 depending on the shop
Posted on Nov 20, 2007
salt56
  • 373 Answers
SOURCE: RCA CONVERGENT PROBLOM
The convergence problem is likely to be in the convergence power supply which is located above and between the two boards which lie flat inside the chassis. The power supply has a chip on it which is a common problem (If it is not the transistor type then change the whole board.) part number on the chip where the metal heat sink is located. Part number may be STK 730-010 or STK 730-130 both number will work and must be unsoldered and new soldered in.
Posted on Jan 05, 2008
  • 70 Answers
SOURCE: i have a 52 inch
you can go into the menu and manually adjust the convergence it will look better most likely but a television should always be converged by a professional when first bought any way because they can do things we at home cant. i have mine done by a professional once a year and do it myself once a month to maintain the best possible picture. good luck
Posted on Sep 22, 2008
ladywinn
  • 5138 Answers
SOURCE: convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Posted on Dec 31, 2008
I have an RCA P52830BL chassis PTK195BB that worked for two days then started sparking. I have had it unplugged. How can I fix it? it had a beautiful picture and sound quality.
chances are it is the flyback transformer or they are also famous for the HV splitter to have issues to. That chassis had about 20 different versions but you can get parts and free technical assistance from www.tvrepairworld.com they have alot of experience with that chassis design
Feb 07, 2013 | RCA P52830BL 52" Rear Projection...
Bad convergence rca d56w20
if model number is correct this is not a do it yourself repair.
Confirm actual model number and I will help you.
Nov 19, 2011 | RCA D56W20 56" Rear Projection Television
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
My Sony Big screen,57in.,Model #KP57WS510,the age-Feb.2004. I turned it on,it looks like i need a pair of 3-D glasses to watch it.Red and green outline the people or objects.Not so much in the...
The following convergence repair kit also applies to your model sony The kit contains the two convergence ICs all six pico fuses and four of the 4.7 ohm resistors. It also comes with free installation instructions and free tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
I have a 52 inch sony rear projection tv, model number kp61s75 with a convergence problem, can i fix it myself or do i need a tv repair man to fix it?
Sep 22, 2008 | Televison & Video
3d image/sinking effect
This is a convergence problem. Ther are either bad connections at the convergence ICs or the ICs are defective. If you can solder, you can repair this yourself. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace the ICs. These ICs are large, black and attached to a heat sink. They should be marked STKxxx. Figure on $20 for each one. There will be 2 of them.
Keep us posted.
Dan
Jun 02, 2008 | RCA D52W19 52" Rear Projection Television
CONVERGENCE OUTPUT I.C.
Nextag and eBay are turning up nothing for this model. In comparison to other manufacturer's prices, the quoted price is not "unreasonable." Projection TV repairs are certainly not cheap. Sorry.
May 24, 2008 | Samsung HCN653W 65" Rear Projection...
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
