Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
F30 on Whirlpool duet washer
The washer is brand new and will not fill with water at all and reports a f30
  • 487 Answers
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct whirlpool_customerexperience@whirlpool.com
Posted on Jun 18, 2008
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F30
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
Here is the service manual.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F30 error
Dispenser system error,make sure the dispenser is clean
Jan 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
