Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp TV only gets black and white from my Hi Def DVD Player. What up?
2 Suggested Answers
  • 1039 Answers
SOURCE: speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Posted on Apr 25, 2009
No audio
You have to have the cable with three colors, yellow is video, white is one side stereo and red is other side. Plug into av on back of tv then select the av
Dec 25, 2013 | Philips Blu-ray Disc Player with Wi-Fi -...
Black and white screen when external device is plugged in via yellow red white cable connection
Make sure your connections to the TV are in the right place. Sounds like you're using the hi def connections when you should be using the analog connections on the TV
Dec 25, 2013 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I need to know which outlets to plug into with the cables, so I can hook it up to a Centrex CTT5103 colour TV.
you have a Dish/Sat or Cable........the cable from any one of these go to the TV (in) or if you have HI DEF.. connect it by color to component 1 (in) note the must be set on channel 3 or set to component 1if HI DEF .........you have DVD player,,,, these wires (yellow white & red) are connected to the TV AUX /Digital (in)
Apr 10, 2011 | Televison & Video
Why can I only get a black and white picture? the unite came with white, yellow and red cables and the back of my Hi-Def Sony T.V has white, red, blue and green. Audio is working great, I had to plug the...
how many aux inputs does your tv have?(vid1,vid2 etc.)there must be a set of component inputs you can use to hook up your player. Another thing you can do is to hook up your player using the S-Video connector if one is provided on both devices(you will need the cable for s-vid).
Dec 30, 2009 | Philips Magnavox MWD200G DVD Player
I have for the first time hooked a sharp aquos LC-46D64U to my basic Direct TV cable (Not High -Def) and the picture lookd all ghosty and watery. I tried adjusting the picute controls and it seems to have...
A 46'' TV is zooming all the defects, to make sure is not a problem with your tv, try with a DVD Player using at least a set of Component cable or HDMI will be the best way to test it.
Dec 06, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
Connect dvd player to tv
look in the tv if input if only for HD or have other imput,may be you have put in the input wrong
Aug 11, 2008 | Sharp 21" Multi System Stereo TV
Black and White on TV
europe uses PAL and not NTSC..change the setting on the TV or DVD player accordingly. Set the TV system to NTSC or the DVD system to PAL
Nov 09, 2007 | Audiovox D1708 Portable DVD Player
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
145 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
