Clarion is a leading manufacturer of high-performance in-car entertainment systems - from acoustically advanced amplifiers, speakers and subwoofers to ...
Get your next HC307-A Clarion B8260-7997G directly via Croooober Japan, ... 20P) / radio antenna conversion code / iPod connection cable / manual only ...
Serial No: 0019379 Clarion made (part number: B8260-7997G) Body Instruction manual GPS Power wire iPod cable Sensor coupler A set of radio antenna Behavior ...
Hello cheriemd,
To adress your first problem i would suggest disconnecting your battery and then reconnecting it, this should trip the radio and bring it back to default settings. As for the second question, Yes you can play your mp3 player with your car radio. There are differnt ways you may approach this, i woudl suggest buying a radio connector that will boardcast its own frequency from there you will be able to switch to that cannel and play. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it
I look forward to your posts
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
