Question about Brother Office Equipment & Supplies
I have a brother fax machine model 2480c, just want to know for the ink catridge, do i need full ink in the entire 4 catridge in order for the printer to work OR i can just have say the black colour catridge with full ink & the other colours' catridge with empty ink, & the printer still works?
  • vincenzina_w Nov 12, 2010
    i have already put in a new balck catridge, but there's still message on the machines saying catridge is empty... so, does it mean that i have to put in new catridge for ALL other 3 colours?
    plus if i only use black ink to print, when it runs out, of course i'll buy another new black catridge, but do i have to buy the other three colour catridges EVERY time? it's kind of wasting money... thanks
How do i change the ink on a brother intellifax 2480c?
Pull down the ink door and then push down on the ink to be replaced, it is locked and spring loaded. When you push down on the ink it will release and allow you to remove it from the machine. Just throw it away and install the new ink in the revese order.
Mar 06, 2011 | Brother IntelliFax-2480C Fax
We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
Let me know
Jan 09, 2011 | Brother IntelliFax-2480C Fax
I recently purchased a refurbished Intellifax 2480C. When I attach it to the power line, the Fax button lights up and I am unable to bring it to the Copy button. 2. I have put in a Black cartridge but the...
Yes, you need to have the color cartridges installed. The print head could be damaged by running cleaning cycles without ink for the entire system. Since the Copy mechanism is the same as the Print mechanism, it explains why you can't enter the copy mode. The unit will store faxes in memory until the memory is full - so the unit will work in Fax mode for a while.
For manuals and additional information, see http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/fax2480c_us_as.html?reg=us&c=us&lang=en&prod=fax2480c_us_as .
I wish that I had better news.
Nov 20, 2010 | Computers & Internet
I have a 2480C printer and Fax but no disk to install? What can I do?
You can go to brother.com and look under the '"Support" heading for downloads that are free of charge and download what ever drivers you need.
Mar 29, 2010 | Brother IntelliFax-2480C Fax
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I need to email a printed document, is there any way to scan it and save it as a file on my computer?
I also have the same machine and it says in the book using you adf as a flatbed scanner, unfortunatley it does'nt tell you how.
If this machine doesn't do what they say than it should be recalled. after all they''re the ones who claim it does in there manual. very misleading!
josephking.tss@gmail.com
May 23, 2009 | Brother IntelliFax-2480C Fax
How do i install the equipment
Plug in the power cord
Plug the phone cord into the LINE port of the fax.
It should be set to AUTO RECEIVE out of the box.
Jun 24, 2008 | Brother IntelliFax-2480C Fax
103 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
