Question about Hayward SUPER II PUMP STRAINER COVER O-RING
My hayward super II pump output return pressure to the pool is very low.. The PSI readings seem normal and I can't see any visible blockings... How else can I test? What can be the problem?
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Start with the impeller and strainer baskets. Excessive debris in the basket(s) in front of the pump can reduce flow rates. Another possibility is debris lodged in the impeller vanes. If the baskets do not solve your problem shut down your pump and back out the 6 bolts holding the motor into the pump housing. Pull out the pump end and remove the diffuser covering the impeller (sometimes the diffuser sticks inside the housing and the impeller will already be uncovered). Use a zip tie or something else of similar strength to run thru each vane looking for things such as small toys, marbles, rocks, mulch etc. Once cleared reassemble the pump being careful to align the diffuser back over the impeller and into the pump housing correctly.
If nothing can be found in the impeller and the baskets are all cleaned and still you have reduced return pressure you will have to get into your filter to find the trouble. If you get that far, please post a comment with what brand and model filter you have for more guidance.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 12, 2010
Who often should I backwash sandfilter
I would let it run for about a minute depending on how clogged it was. Our backwash drain is very visible so we can see when the dirty water has left the filter, usually about a minute or two.
Apr 06, 2013 | Hayward SAND FILTER, PRO SERIES
My Hayward 1 hp super pump will run for a second and then trip the gfci. What has happened? Thanks.
Normally the GFCI is doing its job.
Water is getting into the internal of the motor.
Try replacing your Shaft Seal
Jul 31, 2012 | Hayward 1HP Super Pump II Inground Pool...
The pressure gauge on top of the filter only reads 5 psi. I backwashed and added DE and it still only reads 5 psi. It also read 5 psi after filter was backwashed and before DE was added. What prompted me...
Is there good water flow? Can you feel good flow at the pool return?
If so, using your hand, try to stop the flow. Does the pressure go up?
If the pressure goes up, something inside the filter is not presenting resistance to flow as is normal; it could be a broken element, etc.
If there is no flow or if the pressure doesn't go up, make sure that there is no obstruction in the line coming from the pool to the pump. Check the inlet basket, inlet strainer in the pump, look for debris in the pump inlet & pump outlet piping.
Gary
Aug 20, 2011 | Hayward 1.5 Hp Northstar High Performance...
The water pressure on my Hayward pump on the return is too powerful?
CHANGE OUT THE IMPELLER . HAVE THE HP AND TYPE OF PUMP YOU HAVE ,SAY A SUPER 2 OR A SUPER OR NORTHSTAR. OR BRING YOUR IMPELLER )SCREWS OFF( TO YOUR LOCAL POOL PUMP REPAIR GUY..SAY..The water pressure on my Hayward pump on the return is too powerful? I NEED A SMALLER IMPELLER THEN THIS ONE
Aug 21, 2010 | Pool & Spa
What to do about 14 psi ?
The actual pressure depends on how clean the sand is, how well the pump is pumping, how clean the skimmer and pump baskets are. The rule of thumb would be when the filter pressure raises 8-10 psi above whatever the pressure was when you first started the filter with clean sand, clean baskets, good pump, When it reaches the 8-10 psi, it's time to backfulsh. A low pressue, with adequate return flow is what you really want. See Hayward's web site for a manual. http://www.haywardnet.com/inground/products/manuals.cfm
Jul 06, 2010 | Hayward SAND FILTER, PRO SERIES
My pump pressure is 10psi i cleaned the de filters they seem fine i have good floe out of my jets but when i hook the pool cleaner up pressure drops to almost nothing. could my impeller be the problem
The pressure you are reading is the pressure in the filter tank as water is pumped though it. When the filter is freshly charged, 9 PSI is a good pressure.
As the filter removes particles from the water the filter gets "dirty" -- it takes more pressure to push the water through it thus raising the PSI.
I think you are viewing this in reverse. Low filter pressure is "good" (as long as it stays above 8 PSI) -- as the filter cleans the water the PSI will increase -- when it gets to 15-20 PSI it needs to be back-washed and recharged.
The pressure drops when the pool cleaner is connected because pool cleaners always pull in air (in varying amounts) because of all the hose connections. This causes your filter/tank pressure to drop.
May 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
Hayward SUPER II PUMP STRAINER COVER O-RING Logo
185 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
