Question about Toshiba Satellite U305-S5097 Notebook
Keys are sticking ,touch pad don't work and plug want stay secured
My neighbor disabled my Toshiba touch pad. what do i press to re enable it?
Start menu. Control panel. Go from there with keyboard options and it should work. OR research stick keys/ on screen keyboard
Feb 24, 2015 | Toshiba Computers & Internet
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
Oct 06, 2011 | KitchenAid KESC307 Electric Kitchen Range
My Emachines E625's touchpad has stopped working. What can I do?
it stopped working how.. its not powering at all? if yes, try to remove battery, put in power adapter and try to power it. if it powers, plug in battery while machine is on.
May 04, 2011 | Acer Aspire 3000 Notebook
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
I have a 7 year old GE JBG910 gas convection oven. It recently started having a problem with the keypad. Certain numbers in the numeric portion of the keypad will not work and or beep. I an currently...
This sounds like the key pad needs replacing. The key pad is usually has a self sticking adhesive that secures it to the erc electronic range control. This is easy to replace. Try this link it should help http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | GE Profile Spectra JGB910 Gas Kitchen...
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Error message F7 on my oven
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the (ERC)= Oven control board
Sep 14, 2009 | Ovens
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Apr 26, 2009 | Acer Computers & Internet
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Toshiba Satellite U305-S5097 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
