try running a wash cycle with a packet of unsweetened Lemonade Koolaid in the detergent compartment. No detergent, just the Lemonade Koolaid. The citric acid in the Koolaid cleans away lime deposits that clog things up. Works like a charm! My dishwasher cleans better and smells better too. For 20 cents it is worth a try.
if its giving off that strong smell then the motor is bad. probably caused by not keeping the filters clean. on any bagless machine one has to clean the entire vacuum after almost every use to keep the unit operating correctly
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors. trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids. run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
