Question about Remington Garden
The switch is bad I need a new one part# hy35d
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
John Deere 4230 new starter replace battery also and still will not start
Ignition switch, connections at switch, or small post on the starter solenoid, or wire broken between the two. Or possible bad "new starter solenoid". It's been a problem for other starters. May be a bad batch of solenoids. You may be alble to veryify the solinoid by a jumper from the positive battery terminal or cable to the small post solinoid terminal. If it activeates the starter, you know the solinoid and starter are ok and the problem is the wire or connection to the starter switch. If you had problems before, It may be a bad ignition switch and the internal starter switch. Did you test the old starter? you may not have needed to replace.
Mar 27, 2015 | John Deere Garden
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
Headlights wont work
one of two things
bad dimmer switch or bad headlight switch
Play with the dimmer switch with headlight switch ON.. (on and off severl times) at night to see if your light come on. if they come on you know it's you dimmer...if not its probley need new headlight switch..Hope this will help you??
May 21, 2011 | 1995 Buick Century
Actually ours is a Princess II made by Filter Queen, purchased in 1987. Wondering if motor going bad because when switch on sometimes it starts fine but other times you have to push the switch several...
It sounds like it's probably the switch. It could also be loose wiring connection to the switch, which can result in sparking. This presents a fire and/or shock hazard. Don't use it until you get it repaired. I do recommend having the vacuum checked out for a definite diagnosis. You're right about it possibly needing a new motor.
Mar 30, 2011 | Filter Queen Majestic Canister Vacuum
Need new on/off switch.
You can easily buy it from the Electronic Components shop. Or u may even restore your old switch. Try putting a drop or 2 of Philips Switch cleaning oil in it. I can get it for u if u like.
Oct 09, 2009 | Northgate STAC2217L (Bundle) PC Desktop
No power, new battery
Assuming that you didn't just aquire it, it's likely either a faulty solenoid or starter switch. If you just aquired it, it could also be a bad or disconnected seat or brake switch.
To test the solenoid, put a voltmeter between the chassis or battery NEG terminal and the small terminal on the solenoid. Does it have 12V when you try to start it? No? you need to test the start switch and the safety (seat and brake) switches. Yes? Check the voltage on the 2 large terminals on the solenoid. One should have 12V all the time, the other should have 12V when you try to start. Does it? Yes? bad or disconnected starter. No? bad solenoid. Testing the safety switches involves testing the resistance (ohms) of the switch. It should toggle between infinite and around 0 ohms as you actuate the switch. If it doesn't, it's bad.
May 15, 2009 | Briggs & Stratton Garden
Old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
Mp: bad gap home
Bad GAP HOME is a problem with the sensor (switch) that senses the automatically set printhead gap. Usually the wires break from flexing that run to the switch. Could be a bad switch also, or others.
You need to test the switch and wires with a meter.
Jan 03, 2008 | Printek FormsPro 4500 Matrix Printer
Garden Logo
500 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
