Question about Acer Aspire 5315 Notebook
On startup of my acer aspire 5315 laptop i get the message " no bootable device insert boot disk and press any key"and nothing i have tried can get me past this screen.I can't even get get into the advanced options menu to try safe mode or last known good configuration.What else can i do?
  • crispee Nov 12, 2010
    what happens when you open the BIOS does it see your hard disk? If it does then you can try to boot with a windows OS CD and try a recovery console, if you get this far try running chkdsk /r once done reboot the system and see if this fixed it, if not you may need to boot the OS cd and do a repair install. If this all fails it may mean your hard disk is dead, you can test this by running a hard disk check tool like WD diags or Seatools depending on the type of hard disk that is in your system.
    Novelist:
  • 107 Answers
Hi Charles, I apologize for the inconvenience. In this case what you could try is to get into the BIOS screen for the laptop by pressing the F2 key as soon as you turn on the laptop.Once you are in the BIOS screen please use the right arrow key to select the tab "Boot" below boot make sure that the hard drive is the 1st boot device(you can change the order by using the F5 and F6 keys) and then load the default settings in BIOS using the F10 key and select "YES" and the computer would restart once.In case after performing the above steps the issue still persists then the issue is with the hard drive on the laptop not being detected and if the computer is still covered by warranty please contact Acer and do get the laptop repaired or else you could have a local technician replace the hard drive for you.
Best wishes for your effort.Thank you for your time and patience.
Posted on Nov 12, 2010
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
No bootable device --insert boot disk and press any key
Sounds like your hdd has crashed. Look for a replacement hdd.
Feb 02, 2014 | Acer Aspire 5315-2326 Laptop Computers
Ace r5315 No bootable device insert disk and press any key
Open the hard drive bay and ensure it is plugged in correctly. If that isn't the problem, try testing the hard drive. If it's ok, then the motherboard is gone.
Dec 19, 2011 | Acer Aspire 5315 Notebook
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I cannot boot my acer aspire 5315 laptop, No boot filename received. PXE-M)F: Eciting broadcom PXE Romm. No bootable device. Insert boot disk and Press any key. Please can you help. Mant thanks
It looks like your hard disk went invisible, and BIOS is trying all alternative boot options before it says that there's no boot device available.
I'm afraid that the most probable diagnosis is that the hard disk is broken; anyway you'll need hands-on service to establish what's wrong and what can be done.
Oct 18, 2010 | Acer Aspire 5315 Notebook
When I turn on my acer 5115 it says no bootable
it is possible that there is a mistake in somewhere in BIOS. when booting go to BIOS, and look for booting devices. As a primary booting device should be your HDD, or ODD first and HDD second.
apply these changes and see if the problem is fixed.
if it isn't, it is very likely that your HDD is not working anymore
Nov 14, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Jun 07, 2009 | Acer Aspire 5315 Notebook
Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Mar 21, 2009 | Acer Aspire 5315 Notebook
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
