Question about Miele S514 Solaris Electro Plus Vacuum
The vacum doesn't turn on when we push the swittch
    Genius:
  • 1,672 Answers
Check first the FUSE inside if its already blown and replace it! Taaah!
Posted on Nov 12, 2010
The part that vaccums the carpet will not turn. I checked for hair and debris thinking maybe that is the reason it is not turning but it is clean the attachment works great it is getting good suction...
If your roller doesn't turn, it's most likely your belt. Unplug your vacuum, take pictures as you go for easy re-assembly. The nelt is either accessed from a side plate that will say 'Belt' or from underneath by removing the screws on the cover. They slip on and off for easy repairs.
Sep 05, 2011 | Fantom Vacums FM741 Twister Bagless...
My vacum roller brush dosenot work
The most common failure there is the drive belt from the motor to the brushes has failed. Consult your local vacuum store for a replacement. Normally they are fairly easy to change. Check and see if the brush is free wheeling or needs a push to get it to turn. If the belt is broken or worn out the brushes will turn freely.
Mar 30, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Dyson DC17 Found the clog-how do I unclog it?
poke it out with a screwdriver this will dislodge the hair it might take a while to get it all out
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Self propel feature is not functioning. have to push the vacum cleaner
Remove the bottom plate and look for broken or loose drive belt to the wheels. Check the wheels for being bound-up with thread, hair and other debris. Make sure that the motor for self-propel runs when turned on.
Aug 15, 2009 | Vacuums
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
Mar 22, 2008 | Oreck XL21 Bagged Upright Vacuum
My vacume is the purple one
Hi
Ensure clutch selector knob front left lower side is in drive mode when you pull back the handle to vacuum.
http://dysonmanuals.llc.nu/
Chris.
Dec 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Spin vacum won't suck up water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid is not locked down all the way.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC07, too much suction...?
sounds like one of the filters is either damaged IE a hole or tear or is not seated correctly
Jun 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Miele S514 Solaris Electro Plus Vacuum Logo
215 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
