Question about MSI : 865PE Neo2-PLS P4 Prescott FSB800 Motherboard (MOT43)
Hi.. i need help.. i have trouble with my PC.. after instalation my computer, my hi.. i need help.. i have trouble with my PC.. after instalation my vga can't not detected in my PC. i need Prescott 533 motherboard driver. my mail ID hulan_bhb@yahoo.com PLEASE HELP ME???
    President:
  • 1,812 Answers
Hi hulan ,
intel 865 mother board need intel 865 driver and 865 m board bus speed is 800
but 533 buss speed mother board is 845 m board it will not match with 865 ,so you should download intel 865 vga driver .Go any mother company >support>choice mother model and download it.I should not give any answer to any email id ,sorry dont mind.
Posted on Nov 12, 2010
    Novelist:
  • 107 Answers
Please use the below link to locate the drivers for the Prescott 533 motherboard. http://www.bioticaindia.com/prescott-533.html
Thank you for your time and patience.
Hardware can't detect when install on PC. Is it has failure? how to solve this problem?
This can be due to these two reasons:
1) If your hardware is new, then you are not installing it correctly or haven't installed the drivers associated with the device. A driver is a piece of software which tells your computer how to operate this device. So, look at the manual of your VGA card and install the drivers from the set of CD enclosed inside the box.
2) If you are sure that your system is not detecting at all and you have checked the present piece of hardware on an other system as well than there has to be a problem with your hardware i.e. VGA Card. Get it replaced.
Oct 23, 2012 | NewTek VT[4] for PC
Sir, i have installed the windows 7 os in my pc. But i have problem that i am unable to install the vga in my computer from tha motherboard CD. ineed to install the vga now. So please help me to install...
Hi, I am Steve, lets get you some help.
The reason it wont install is because it is not Windows 7 compatible which is not a surprise. You need to go to the support site for your graphics card and download the correct driver for windows 7.
Did you check for Win 7 compatibility before installing?
I can give you more detailed instructions if you tell me the make and model of your computer.
Feb 06, 2011 | Computers & Internet
Device type direct 3ddoes not work
Hi You have this problem because your VGA driver is not installed. You can try to detect your graphic card by entering this site : http://www.ma-config.com/en/home/ then click on "Run the detection" After installing the plugin you can see all the drivers you have. Select the VGA driver and then download it. Finally install it. I think the solution is very clear. if you have any question, feel free to reply to this message.
If you like my solution, please rate it. Thank you for using fixya
Dec 11, 2010 | Computers & Internet
I had purchased lenovo g450 laptop.when i format my laptop after that when i want to install vga from drivers cd than cd vga setup didn't support laptop hardware.than wat can i do now.tell me
Hi There,
VGA may be installed latter than OS. It may be detected by itself.
Proceed with Windows installation.
Please rate this solution and comment to keep in touch.
Sep 20, 2010 | Computers & Internet
I unable to play a game because VGA compatible device not found in my computer & i want to install this. How can i install this explain it? & i am using XP
VGA compatible device not found represents that either your bios couldnt recognize the VGA hardware or your OS pnp service couldnt initialize the Hardware for VGA. Either these cases, we should look for the level of Hardware detection at which it fails. If its an onboard VGA device, you may need to replace it with an addon VGA card based on the Mother Board compatibility and then try install it again. This should solve the issue.
Good Luck.
Sep 06, 2010 | Computers & Internet
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
Want to use my tv as a monitor, how do I activate the vga output?
Hi adiazjr.On the Asus 1000he, in order to switch to an external monitor you need to press the function key (Fn) at the bottom left of the keyboard and the F8 key at the top. When you press both of these keys at the same time it will send the video signal to whatever external monitor or TV you have connected. Hope this helps!
Aug 28, 2009 | ASUS Eee PC 1000HE Netbook
SIR I AM FACING PROBLEM TP INSTALL VGA ON MY
You are correct you need to make sure that you download the correct drivers & install them for the desired performance.
Visit this thread to download the same & run the exe file for auto install.
http://drivers-download-driver.com/tag/index_1002.html
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 21, 2009 | Computers & Internet
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
Dear salam
You are only part way there in installing the software. After XP, you need to install the board specific drivers for it's systems. They should be on a CD that would have come with the motherboard. Once those are installed, everything should work.
May 17, 2008 | VIA Jetway V2MDMP MB AMD SKTA/ KM266Pro/...
MSI : 865PE Neo2-PLS P4 Prescott FSB800 Motherboard (MOT43) Logo
648 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
