Question about Linksys WRT54G2 Wireless Router
I was having connection problems to the internet. A verizon tech came out and said my modem was old and out dated. He replaced it with a new modem but I don't know how to get my linksys wireless router to work with it.
    Novelist:
  • 94 Answers
Most of the modems that Verizon (depending which market you are in) techs are using are combination modem/routers, so you may not need to use your Linksys wireless router anymore. Typically the default SSID (wireless signal name) and password (if there is one) is printed on a label attached to the router. You can use this default info if you'd like or reconfigure the router using the following steps. Log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default username and password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Posted on Nov 12, 2010
2 Suggested Answers
  • 105 Answers
SOURCE: Wireless-G Linksys Router No Signal with Verizon Modem
The first thing I would recommend is to reset the router to its factory defaults. Then reconfigure it according to your Verizon settings.
There are a number of things you need to set, in order for the router to be able to talk to Verizon correctly. These things such as dns name servers, the ip address you connect to (whether it is static or dynamic), and things of this nature. They should have given you all of this information, and if they did not you will need to contact them first or you will not be successful in connecting.
To be more specific regarding the error message, I need to know the specific model you have as well as the version of the software.
If you need additional help just post another question here and it will notify me that you have.
Posted on Jun 21, 2008
I have DSL/verizon,modem 6100F i keep loosing my internet connection
Your problem definitely sounds like an intermittent connection problem. It can either be one of two things. #1. You have a defective modem, or #2 It's a network problem. I will definitely go with #2. Here's the thing. The problem you have is very very very common not only to Verizon DSL customers, but also to other Internet Service Providers as well. The best way to fix the problem is to understand what's causing the problem. There are two types of intermittent connection problems. The first is Intermittent Sync. You'll know if you have this problem because the DSL light will be blinking everytime you get kicked out. That means there's no internet connection, The modem cannot detect and establish a connection with the Central Office. The second is Intermittent route (which I know is you're problem), The DSL light is steady, but the Internet light almost always turns OFF or turns RED. The only way to fix this problem is to coordinate with Verizon. The reason is because the problem is outside your house. The long cable lines, the drop wire, the cables that passes through from the Central Office to your House can all be damaged, If that's the case, then a technician is required to go out and fix the problem. Don't worry about calling Verizon, this is a network problem and you won't be charge for anything. I know losing internet connection is very frustrating. Give your ISP a chance, they will definitely fix the problem if you give them the opportunity to do so.
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Cannot connect to my Sony laptop with Windows vista
Hmm..the best way I can think of here is to get both Techs on the same line so that they can discuss what the problem really is. I've tried this before and I have to admit. Things worked out very well, It seems a device built in my laptop was not running properly, so I had to install it again, it's called the NIC or Network Interface Card and it's the device that allows your laptop to communicate with the modem.
Regarding the lights in your modem. The DSL light should always be Steady Green, that means that your modem is in Sync with the network. If it's blinking, check all connections, make sure every physical connection is connected properly, if the dsl light is still blinking, that's a network problem already and you should call Verizon so that they can send a tech to fix it.
Sometimes it's difficult to isolate the problem for an internet connection, but to make it clearer for you and anyone else with the same issue. The modem is the central part of the connection. It's a verizon problem if the problem is the connection of the modem to the central office, and you can check it with the DSL light and Internet light.
It can either be a Verizon Problem or a Modem to PC problem, if the problem is between the modem to the pc. Possible Scenarios here are: The modem is defective, the NIC is defective, the Ethernet Cable is defective.
The first is a verizon problem only if the modem is still covered by warranty, if the modem is qualified for a DSP or a Device Service Plan, then that's good, you don't need to buy a new modem anymore. The second and third issue is a physical problem with the devices already and you'll need to have your pc fixed.
Try and isolate the issue, and if you can, let me know and I'll let you know what you can do to fix your problem.
Apr 29, 2009 | Westell Wirespeed ProLine 6100 Router...
Replacing older model Westell ADSL modem with newer one.
Plug your old modem back in and access it via the browser. Either dslrouter or 192.168.1.1 in the url seacrh bar. Go to configure and write down all the ISP setting and LABEL what sections in the configure they go to for your ISP. Still with me?
The plug in your "new" modem access it the same way and enter the ISP and modem settings from the old modem; it should work.
Jan 20, 2009 | Westell Wirespeed LiteLine 6100...
Cannot connect to internet servers for cod2 pc
update your cod 2 with patches ( see xfire.com)
ad update your punkbuster
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
No Internet light, but an Ethernet light that blinks?
for westell 6100 modem usb driver installation follow the steps for windows xp
-close all programs
-unplug usb cable from the pc
-insert installation cd from verizon
-plug usb cable back to pc
-wizard will pop up found new hardware
-click next then follow instructions
-select usb connection on the installation
Dec 14, 2007 | Westell Wirespeed LiteLine 6100...
Connecting my westell 6100 modem to my router
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
Dec 09, 2007 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 Wireless Router Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
