Question about Frigidaire ATF6000ES Front Load Washer
Wont start any cycle
Washing machine wont start any cycle, does have power to the panel but wont do any thing!!!!
  • Loueezy Dec 06, 2008
    my whirlpool washer won't start. It makes a noise, but no lights come on. The door latch seems to be fine. Please help!
  • 868 Answers
Go to your door latch, there is your first stop.Your power supply waits here at the latch to give the computer a correct start.If its not the latch....I need to know. Post a update on this one. Thanx!
Posted on Jun 25, 2008
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Tub clean cycle
this is not tub clean..its child lock..kindly remove child lock frist,,,
Feb 16, 2014 | LG WM-2277HW Front Load Washer
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Indeset we16, has power door wont lock or start cycle but timer counts down
Fault with the lock mechanism as the lock switch seems to work and so starts the cycle to count down.
Check if the solenoid to the lock is activated from the panel control or it can be that the lock is defective.
Jul 02, 2012 | LG Washing Machines
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
My washing machine, after washing, changed to the spin cycle then started beeping so I turned it off, re-started it & when it got to the last spin cycle it just beeped then stopped. Now it wont start. It's...
No power? Let's see if we can solve this problem.
  1. Unplug then plug back again.
  2. Start the program.
  • If beeping send for repair/replacement.
  • If not beeping be happy to continue using your washing machine.
Jan 21, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
495 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
