Question about LG LDF8812 Stainless Steel Built-in Dishwasher
My LG dishwasher is flashing LE. What does that mean? Is there anything I can do or do I need to call a technician? Thank you for any help you can give me. Colleen
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
Posted on Aug 27, 2008
  • 423 Answers
SOURCE: le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
Posted on Apr 06, 2009
  • 37 Answers
SOURCE: What does the error code LE mean on my LG Dishwasher
MAin wash motor needs replacing
Affordable Appliance Repair
Lake Forest, CA 92630
Posted on Aug 22, 2009
dutchman05
  • 487 Answers
SOURCE: I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Posted on Jan 12, 2010
I have a LG dishwasher, and from the word go I've had problems, I try not to use it any more. it started with flashing LE and bing bing bing all the time, now it flashes HE, I think its time to throw...
the le code is motor code the motor is not turning the he code is heater code if the motor is locked it will also bring up the he code because the over stat on the heater will cut out because the water cannot circulate
Oct 25, 2011 | Dishwashers
WHAT DOES IT MEAN WHEN LE POPS UP AND THE DISHWASHER STOPS RUNNING.
You have a motor problem and it needs to be checked by a qualified technician.
Jun 16, 2011 | LG LDF6810ST Stainless Steel Built-in...
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
LE code what is it???
most of the time a le means the motor. you should call for service it may have a 5 year wnty.
Feb 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
365 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
