Question about SAMTRON 55V 15" CRT Monitor
The problem is power out put voltage diodes are completely burned I not getting the value of the diodes The voltages are 72v 50v 6.3v 13v -12v These are out put voltages .so please sending me values of diodes.
    Guru:
  • 452 Answers
Hi;
  1. Diode: UF4007, 1000V 1Ampere ; for 72V
  2. Diode: GUR460L, 600V, 4Ampere : for 50V
  3. Diode: UF5404,400V, 3Ampere: for 6.3V
  4. Diode: UF1G, 400V, 1.2Ampere: for 13V
  5. Diode: TVR10G, 400V, 1Ampere: for -12V
Posted on Nov 12, 2010
Q770 model no-cdt 17109a-2a
seral.no-243450 power supply proble
ster are filled
Posted on Nov 28, 2012
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Cook temp not working
follow this steps and test with VOM. God bless you
Diode
Enter your model number to see parts for your microwave.
Help me find my model number
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
Apr 02, 2013 | Maytag MMV4184A 1000 Watts Microwave Oven
Morphy richards oven is not heating and not cooking anything
please proceed according and fix it. God bless you
Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
Mar 01, 2013 | Morphy Richards Microwave Ovens
Code f-33
Step 1:
Symptom: Intermittent or continuous error code F33 on the display. Cause: Insufficient (poor) grounding of the controller (DP) board.Remedy: clean the groundHowever if Not Heating proceed with the next steps.
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 07, 2013 | Microwave Ovens
Can't get to heat anything can't seem to set clock first Hamilton beach model hbp90d23al any suggestions
Step 1:
see this steps and diagram and fix it. God bless you
Microwave Doesn't Heat
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Step 4:
Maytag 4205baw runs but does not heat any items
Step 1:
Follow this steps and see the diagrams.God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 06, 2013 | Microwave Ovens
Why is the microwave not heating the food, but the turntable is hot.?
Step 1:
folloq this steps and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Heating problem
see this causes and fix it. God bless you
Sep 27, 2012 | Microwave Ovens
Model pm0525312.18 serial 914080230 engine runs good but the voltage drops of from about 125volts to 90 volts when you put on about 1500 watts. does this model have a voltage regulator? what is a bridge...
According to the parts pdf, there is no voltage regulator. Voltage is adjusted by the rpm of the engine. If your have a meter that reads hertz (Hz), you can set the engine rpm by adjusting hertz to 60 cycles (Hz). At 60 cycles the engine is running at about 3600 rpm. Most engines develop their max horsepower at this rpm. If you are loosing power/voltage and the engine speed is not dropping below 3600, than most likely could be problem with capacitor, brushes or diode (bridge diode). The diode converts ac voltage from stator to direct current to power the magnet (rotor). Check for brush wear and test capacitor for value printed on part. It should test with 5% of stated value. Diode can also be easily tested with meter. Good holidays
Dec 05, 2010 | Coleman Powermate Powermate 5000W...
SAMTRON 55V 15" CRT Monitor Logo
519 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
